Que tal tengo un problema de instalacion con mi impresora SHARP AL 1642cs para windows vista de 64 bits ....Como puedo solucionar esto? necesito los drivers .Gracias
Ir a la ficha www.sharpusa.com de atención al cliente a continuación, descarga de productos. Categoría de producto elegir impresoras y multifuncionales. para el modelo seleccionado modelo no figuran a continuación, el tipo de modelo en AL1642CS. Para el tipo de descarga a continuación, elegir controlador presión de búsqueda en la parte inferior.
We have a canon np6551 copier that was given to us but when it is turned on it warms up and says...
(More)
We have a canon np6551 copier that was given to us but when it is turned on it warms up and says ready to copy but when you touch the screen or try to set number of copies or push start nothing happens.
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant...
(More)
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant connection (only 1) in back of tv-vcr unit and the yellow and white connections in frt of unit are connected via a cable with r-y-w to converter box and y-w to frt of tv unit. At the advance record screen..channel 3 is showing in the selection box, if you insert a different channel it will not record that channel/program. Are there any converter companies that had the foresight to know that there are hundreds of tv-vcr combos still in use? I understand the mechanics for a stand alone vcr and I know how to manually record on the combo..but I want to be able to preset and for more than one channel and recording times. Thanx
