Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
How do I change the blade on my trimmer?
How do I change the from spool trimmer to bush trimmer blade on ry30570
    Master:
  • 969 Answers
1-800-345-8746
Posted on Aug 23, 2009
How do i replace the starter rope on RY30570
Remove screws holding front and back plastic casing. Remove trimmer shaft with casing. Watch out for spring when you remove the string reel. Best thing is to push the knot out of handel and either cut it or untie it to release all tension on the spring before removing the string reel. The rest is kind of learn as you go.
Aug 11, 2013 | Ryobi 30cc 17" String Trimmer Zrry30530...
How to stop trimmer line spool from spinning off
I bought a Shakespeare Push-n-Load 3 blade trimmer head at The Home Depot for about 26 dollars and picked up a pack of 12 replacement blades for another 7. Did a whole 3 acres worth of weed whacking and still didn't need to change the blades. I was also powering through some pretty thick bushes with ease. Highly recommended.
Apr 13, 2013 | Craftsman 25cc Gas Line Trimmer
Blade on a Craftsman 20 in bushwacker electric hedge trimmer stuck on a vine and will not engage
with engine off ! use a pocket knife to whittle wood branch out of bar , do not yank it off the bush the blade will bend then will become stuck
Mar 10, 2013 | Craftsman 20 in. Hedge Trimmer
Can't remove spool from Black & Decker GH1000 weed wacker
UNscrew the cetral screw with a flatheaded screwdriver, then put the flate blade of the screwdriver in through the side slot where the cap clips in, and gently pry up on the spool from underneath it.
Sep 03, 2010 | Black & Decker 14" Grass Hog Xp...
Change cutting line
Pop of bottom cover and wrap new line by turning head or replace with different spool or blade cutter
Jul 01, 2009 | Craftsman 22" Gas Hedge Trimmer
Which way do you wind up the trimmer line so it doesn`t hang up on the spool when you need more line?
The direction of winding is on the spool and/or in the manual, if the line is getting stuck here are some tips:
Use only premium quality line of the correct size and shape, do not buy the mega rolls that will last you a lifetime rather buy the small roll each spring as the line can get brittle and weaken over time.
Avoid winding the line tight like fishing line on a reel and while winding occasionally dust it with baby powder.
Do not fill the spool with line more than half way.
Practice running the trimmer only fast enough to do the job, running the trimmer wide open is necessary only to add power for thick weeds. Running at high RPM makes the gear head, spool and line to overheat which can make the line 'vulcanize' to itself. You will also find that running at half or less speed uses up much less line and will make the trimmer last longer.
If you find that much of your trimming is in high, dense weeds such as a ditch that gets trimmed three or four times a year you may want to invest in a different head that utilizes plastic blades that swing out when spinning, these are much better than they were in the past and work great by limiting the cutting to a smaller area, they are stiffer and cut heavy weeds better. I chose a trimmer with the strait shaft and quick-link so I can easily change from the brush hog, line or swing out trimmer. I use the line trimmer only in areas where a deft touch is required such as around trees, shrubs or other delicate plants I do not want to accidentally scar or damage.
May 14, 2009 | Ryobi Garden
Step by Step spool filling on my NEW Black & Decker GH700
Check the bottom of the spool. See the pattern that looks like a circular saw blade. Ensure that the raised edges, do not have any broken/missing sections. Also, check that the pivot lever in the cap, moves freely and engages the space between the same, saw-blade-like edges in the spool correctly. If there are broken/missing sections of the spool, replace the spool with a good one.
Apr 29, 2009 | Black & Decker String Trimmer Cordless 12"...
Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
257 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
