Question about Canon PowerShot G1 Digital Camera
Battery is fully charged but camera will not power up
After battery is charged and put in camera there is no power when you turn on the camera.
  • Anonymous Aug 25, 2008
    Same as above. Battery fully charged and nothing happens when turning it "ON"
    Novelist:
  • 159 Answers
Check you manual .. is there a 'back up' battery (coin cell ??) .. if not then the battery is dead (rechargeable batteries do not last for ever) .. try a brand new battery
Posted on Mar 22, 2008
My sl102 samsung wont turn on
Are you sure the battery is correctly charged?
Most USB connectors on most PC's don't deliver enough power to charge the battery. Try to charge the battery with the power cord till the green LED is on.
If you'r sure the battery is fully charged and the same happens again, remove the battery for a small time and put it in again.
Feb 20, 2013 | Samsung SL102 Digital Camera
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot SD1000 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Hello. My v1233 powers on, I am prompted to put
4. Please test with the a different battery
  1. Please take the battery out of the camera.
Steps for uploading new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://wwwuk.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11647/11660&product=EKN033563
If successful please give me the feedback as a rating or recommendation. Thank You
Dec 08, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Canon S2 IS won't turn on with rechargeable batteries??
I would let them charge til you get an indication that they are done. TV remotes require very little power to operate, while digital cameras need a lot, so that's why the batteries would work in the remotes though not fully charged.
Jun 16, 2007 | Canon PowerShot S2 IS Digital Camera
DSC-T7 Power Problems
The only and the only solution is to get the replacement as this seems to be a defect in the camera and you should get it change immediately.
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Canon PowerShot G1 Digital Camera Logo
213 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
