Question about Xerox Phaser 8560MFP Laser Printer
Inbound faxes - want to store them.
Xerox 8560MFP - Can it be setup to store all inbound faxes. Either on the disk or on the network
    Scholar:
  • 141 Answers
Nope. Your best bet is to either use a PC as your receiving fax or get a machine that has fax forward to email capability.
With the 8560, you can just train all your users to grab incoming faxes and immediately scan them to a folder on the network. You probably don't want to scan them to the memory of the machine but you could do that as well and they would be available through the web interface.
Posted on Aug 04, 2009
Master reset xerox 8560 printer
Your Administrator Guide book should have these instructions listed for you. It should be on the CD's that came with the printer.
If you have lost/misplaced them, you can download the guides from the Xerox.com website.
The steps below are what I did from my laptop as a Repair Technician:
1. Connect a crossover cable between the PC and system. To print an Event Log or Runtime Log:
2. Verify the system is Ready.
3. Use the system's control panel to enable AutoIP:
a. Select the system Setup menu.
b. Select the Connection Setup menu.
c. Select the Network Setup menu. 5. The page should now print.
d. Select the TCP/IP Setup menu.
e. Set AutoIP to On.
f. Exit the menu so the system is Ready.
4.
NOTE: To print the Connection Setup or Configuration page, select the system Setup
menu.
Reset the system to cause AutoIP to assign a new IP address (cycle power or select
Restart system from the Shutdown menu).
5. After the system's IP address is set, test communication by sending the "PING" com-
mand.
6. If the test fails, install a different cable and retest.
Sep 27, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
Network printer sending message on desktop " printer status is not available at this time"
Check the network setups, is it set to DHCP has it been issued with a valid I.p. Address. E.g 192.168.0.123 etc?
try printing out the network setups from the printer, that might shed some light on the problem once you have all the network information at your fingertips it's much easier to make a valued decision.
Good luck.
Oct 24, 2013 | Xerox Phaser 8560MFP Laser Printer
My printer xerox phaser 8560mfp is printing landscape 1/2 page instead of a full size portrait from a pdf file. How do I get that fixed? Thanks!
You need the new driver. Goto the Xerox website and download the latest driver and save it on your C: drive. Goto Devices and Printers and remove your existing Xerox 8560MFP. Reboot your computer and go back to this screen and click on "add a printer". When you get to the screen "Install the printer driver" you will see Xerox 8560MFP PS highlighted DO NOT CHOOSE THIS! (you will simply be installing the same driver from Windows 7 back). Instead, Click on "Have Disk... and navigate to where you saved the driver. Choose that one and finish the install.
May 20, 2011 | Xerox Phaser 8560MFP Laser Printer
I just got a 8560MFP and I am running win 7 64. I can not get the printer to print in colour only black and white, and advise/help?
in your printer driver, Start/printers & Faxes.. Right click the printer Icon for your 8560 and goto properties.
Goto Advanced Tab and then Printing Defaults..
Make sure the Black & White printing is Unchecked.
Jan 14, 2011 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP: When in sleep mode, the printer still wakes up to do a warm up test and then goes back to sleep. How can I turn this off?
Look in the setups.
It might be a good idea to print out the setup sheets. Look under sleep mode and set the time accordingly to what you want.
Alternatly go to the WWW.xerox.com website for assistance.
Good luck.
Oct 03, 2010 | Xerox Phaser 8560MFP Laser Printer
I have lost the setup CD for Doculan Fax running a Xerox Workcentre Pro 645. Is there anywhere I can download this software or buy it secondhand?
1. check the manufacturers site to see if they have the drivers and the setup disk available.
go to the "contact us" link and submit a request for the disk to be sent. Some manufacturers will ask for a small shipping fee and send the disk right away to your shipping address.
I hope this helps
Have great Day!
Apr 13, 2010 | Xerox Doculan Fax (4 Users) (W0M)
How do I find the path to a network printer in order to install it? I had to reinstall the driver but my boss can't find the disk so I downloaded it from the Xerox website. The add printer wizard wants me...
It sounds like whoever set up your network added an administrator code to access.
That driver is pretty much plug and play and sets itself up very easily.
That user name and pass word is not part of the driver setup.
Feb 16, 2010 | Xerox Phaser 8560MFP Laser Printer
How do you fax
the machine has to scan an image in before you can fax?
Sep 28, 2007 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
155 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
