Question about Hayward SAND FILTER, PRO SERIES
Waste line leaking
Trying to begin our second year with new Hayward S-180T filter and filter was doing fine for a day and then began leaking from waste line while filter running. Re did all start-up steps from beginning and it still leaks. the filter/waste outlet continously runs while the pump is on. Mine does the same thing, it wont filter it just keeps sending waste out, I replaced the gasket and the spring and nothing has changed!
  • Samuel Charles Spriggs May 11, 2010
    I assume you have a multi-port valve which is set to "filter". If water is coming out where it shouldnt' be, the problem is usually the gasket under the multi-port valve top.
    Remove the top of the multi-port valve and investigate -- the large O-ring is probably out of place or damaged.
    Please let me know what you find.
    thanks...
    Charlie
    President:
  • Hayward Master
  • 1,378 Answers
When you had the unit apart, did you note the correct alignment of the handle to the diverter? You may have put the handle on 180 degrees away from the correct orientation and therefore flipped all the settings, making filter=backwash, etc...
If thats not it, any chance it has freeze damage inside from not draining completely and therefore needs a new valve?
Posted on Jun 14, 2009
I have a brand new S244T sand filter. During backwash cycle large amount of water discharges out of the waste line. Filter doesnt appear to be backwashing normally. Hayward is sending a replacement head. I...
When backwashing with this valve, it is supposed to come out the waste line. Also when in "rinse" and "waste" it will also come out the waste line. It is acting just how it is supposed to act.
May 26, 2011 | Hayward Pool & Spa
I have a brand new Hayward RS 2sp pump, new DE6020 filter and a new Hayward Vari-flo Valve / 6 positions. When I run the pump at low speed no water goes thru the waste line. When I run it at High speed,...
The spider gasket inside the 6-position valve is probably leaking. Take the model number of the valve to a local pool store and they can order a replacement. You will also need a special sealant to install the new gasket.
Nov 07, 2017 | Hayward SAND FILTER, PRO SERIES
Just installed a hayward pump and followed directions on the pump having problems when we tried to backwash it shoots sand into the pool
Backwash should put no water back into the pool. It should be sending filter dirt to a waste line. Maybe your lines are incorrectly installed?
Secondly, under normal conditions, sand does not go to backwash waste either. Could there be too much sand in the filter?
Gary
May 01, 2011 | Hayward Pool & Spa
What do i do with the waste line port on the multiport valve on a hayward filter. do i attach a fitting to stop air
No. That port is there for when you backwash or pump to waste. You normally put a hose adapter there that allows for a collapsable backwash line to be attached when ready to backwash the filter. If it is leaking water there when the valve is set to something other than waste or backwash yuou need to replace the internal gasket in the valve.
Aug 08, 2009 | Hayward SAND FILTER, PRO SERIES
Problem with vari-flo multipoer 1.5 and Hayward DE fiilter
You need a rebuild kit for the valve and possible a sand change. Sand should be changed ever 3 - 5 years or so depending on overall pool conditions.
The gasket inside the valve is out of place and therefore allowing water to leak out the waste port. Use a gokit to replace all the gasket/orings and you should stop the leak.
If the flow is still bad, inspect the sand and change it if necessary.
Jun 26, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter needs primed every time
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
May 29, 2009 | Hayward SAND FILTER, PRO SERIES
Waste line leaking
handle is not in filter position turn off pump move handle to different position several time make sure that no debris under handel
May 28, 2009 | Hayward SAND FILTER, PRO SERIES
Gasket on hayward 712-2 is slightly warped water comes out of backwash at same time filter is running. need new gasket. temp fix of raising the seat of broken spoke not working. filter runs fine if valve...
Buy a new gasket and install with some sort of gasket lube.
Selector (rotary) valve operation: Do not move selector valve unless pump is off, and always move in a clockwise direction.
'Waste' selection bypasses filter completely and sends water directly out of pool backwash port
May 18, 2009 | Pool & Spa
Waste line leaking
Bad gasket on diverter on the valve
Apr 24, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
551 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
