Question about Denon AVR-1905 Receiver
Denon AVR 1905 Power Switch Issue?
Recently, my Denon 1905 has stopped powering up altogether. I would push the power button or try using the remote and the power won't come on. I've moved it to different outlets to make sure it wasn't the surge protector but still no power. Any suggestions? Is there a fuse or something that may be out? My Denon AVR 785 switches on, the screen shows Digital AV Surround Receiver, and then it goes back into standby mode and the red light flashes around the knob. Is it buggered?
My denon 1905/785 receiver stopped working on zone 2. It has worked for years and just stopped working. It dont know if it simply doesnt work or just wont let me turn the volume up any longer using the...
Try a reset to factory defaults and reprogramming your preferences. Time consuming, but sometimes things go bung inside the microprocessor controllers.
Sep 02, 2013 | Denon AVR-1905 Receiver
Denon AVR 2105 5years old has worked perfectly. Now all of a suddend Zone 2 does not come on. Any ideas why after working perfect for so long?
Bad button on the remote? or
static discharge from being touched can cause all kinds of strange problems.
I would reset the micro processor back to default settings..
RESET PROCEDURE
1. PUSH MAIN POWER SWITCH OFF
2. WHILE HOLDING THE FOLLOWING KEYS DOWN, PUSH MAIN POWER SWITCH ON
AVR-2105 or AVR-885 Front Speaker A and B (2 keys)
Let the front panel blink 3 or 4 times and then release the keys (buttons)
You will have to do your set up again i.e. speaker size, assign inputs, FM presets etc.
Aug 25, 2013 | Audio Players & Recorders
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
DENON -AVR-1905 when power on display appears " 1 FRONT LARGE " and nothing happens no button does not respond.what could be the problem ?
Dear friend. That means you have to use Large Front speakers with correct impedance The other four speakers are for rear and surround effects and they do not need to be large (or floor standing). Most effects will come from Front speakers. I suppose that this is the problem.
Good`Luck.
Flavio/BRAZIL
Jul 21, 2010 | Denon AVR-1804 Receiver
Denon AVR-687 cannot power on, no power light lit around power
Check the main power switch next to the large power button. It is a small push button. If it is pressed in and you still have no light around the power button then very likely you have a dead power supply.
Apr 27, 2010 | Denon AVR-687
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Sep 12, 2008 | Denon AVR-2807 Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
Denon AVR-1905 Receiver Logo
392 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
