Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
How to get my ac to cut off after reaching a temp.
I put my ac on auto and it won't cut off after it reaches the temp. i have set it for., what can i do?
    President:
  • 1,489 Answers
Replace the thermostat.
Posted on May 28, 2009
Unit runs well but won't turn off when tepm setting is reached
In the Remote SET the AC FAN IN AUTO MODE THE AC stops after attains the set temp.
Apr 26, 2016 | Kenmore 18,500 BTU Heat/Cool 230V Room Air...
My ac randomly turns off and when I restart it it does the same again
HOME A/C units are designed to shut off when the desired room temp is reached.it is called Cycling. when the temp control unit senses that the temprature is too high then it will turn the unit back on till it again reaches the temp it is set oto
Oct 01, 2015 | AC Cars & Trucks
AC WORKS FINE HEAT COMES ON BUT WHEN TEMP IS REACHED FAN NEVER GOES OFF AND TROUBLE WITH HEAT COMING BACK ON
When temp reached to thermostat level heatewr only will cut off not the blower. And secondly all thermostat at heat stage will cut off at the end of +2 degree and cut in starting of -2 degree.
E.g; If you keep 30 degree heat it will cut off at 32 and cut in 28 degree.
Dec 07, 2010 | Crosley CAE12ESR Air Conditioner
I have a AZ38H15DADM1 that works fine in heat mode and in AC mode it works great until it reaches the temp it thinks it should be, then it cuts off and never cuts back on without me physically turning the...
When setpoint is reach unit would shut off .
If you put the fan to the ON position it would run all the time and ac would cycle on and off depends on the temperature
Feb 12, 2018 | GE Zoneline AZ38H12DAD Split System Air...
My ac will not stay on when its at a certain temperture or auto. only if its in on position
this is correct because if you set it to certin temp. when it reaches that temp. it will shut down to prevent over cooling when the temp in the room goes up a preset amount 2-5 deg.(preset by manafatuer) the unit should go back on to drop the temp. to your set temp. Auto works the same way, where just on will cool to the temp the system can cool efficently.
Jul 31, 2009 | Heating & Cooling
AC stops working when cabin temp reaches 109-110
indicates gas pressure and condenser cooling problems
check the condenser fan is working properly and have the gas pressures checked by gauges
check that the evaporator fins are clean and not blocked as ice build up will cause the same indications
Apr 07, 2017 | 1997 Audi A6
A/C set to "AUTO" but still won't turn off after temp is reached
you have either a bad thermostat or bad controls in the units unplug the furnace make sure the outside unit shuts off turn off the thermostat plug back in if it all starts with the thermostat off you will need service thanks for the high ratting keeps me helping for free.Tom
Jun 27, 2009 | Panasonic CW-XC243HU Air Conditioner
Ac problems
Sounds like the switches are in the wrong locations , rotate! Thank- you- very-much!
Aug 20, 2008 | Dometic Rooftop RV Air Conditioner
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
155 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
