How do you replace a door hinge on a Bosch w/machine WFO02464GB ?
I need to know if there is anything that will fall down behind the front panel of the machine when I undo the screws holding the hinge to the front panel. If there is something, say like a plate, how do I get the front of the machine off or do I take off the top.
    President:
  • 1,136 Answers
Hi, Could I get the model # so I can look it up. I do not believe there is anything that will fall inside the front panel.
With the #, I can be sur.
Thanks
Vic
Posted on May 28, 2009
How to change the door hinge
Link to PART:
Bosch Washer Hinge - AppliancePartsPros.com
http://www.appliancepartspros.com/bosch-washer-hinge.html
Link to VIDEO - "HOW TO REPLACE DOOR HINGE"
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
http://www.espares.co.uk/product/es486275/washing-machine-door-hinge
Jul 09, 2014 | Bosch WFMC 2100 Front Load Washer
The Front Door Came off of my Bosch WFL 2060 when a huge container of detergent fell on it while open. I think I need a new Rear Door Panel, Gray, Wfl 2060/WFR 2460 because the old one is damaged, but I...
I have same problem. Washer vibrated badly during spin cycle and door subsequently came off because back panel..Mfr. # 00432074 cracked near hinge. Looks to me like hinge must first be inserted before panel replaced. I do not have proper tool either.
Sep 29, 2013 | Bosch Axxis WFL 2060 Front Load Washer
The front door is falling off
I don't have a Bosch, but my Kitchenaid would not stay closed; the door would fall to the floor. There are cables that run along the sides of the machine that need to be replaced because one or both have snapped. Of course, your Bosch could be different. The tech manual is generally located behind the kickplate under the dishwasher; just unscrew the two screws to take off the kickplate.
Dec 05, 2010 | Bosch SHU9915UC Dishwasher
I am replacing the lock, what does the plastic rod hanging down from it do and does it need to be attached to anything
It attaches to a pull strap. The pull strap is in case the switch fails it can be pulled to get the door open. Most bosch pull straps are located behind the drain filter cover (lower right).
Oct 16, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
Feb 06, 2010 | Bosch Washing Machines
How do we fit a new hinge to a Hotpoint WM64P washing machine
Remove the wire clamp that secures the door seal to the front of the washer.
Pull the seal of the front. and double it back inside the washer.
Undo the 2 screws that secure the door hinge to the front of the cabinet, keeping hold of the hinge support plate behind the cabinet front.
Remove the door, and undo all the scews that hold the 2 halves of the door together, then prise apart the the 2 halves..
Replace the door hinge.
Reassemble in reverse order.
Thanks.
Nov 24, 2009 | Hotpoint Washing Machines
How do you remove front panel on a Bosch WFO285SGB
This video will show you how to replace the Bosch WFO285SGB washing machine door seal with step by step guide on the process
Aug 13, 2009 | Bosch Washing Machines
Door Problem
There are set springs for the adjustment of the doors on the Bosch dishwashers. they are colour coded for different applications. They are accessed by laying the machine on its back and pulling the springs out of the base. first you will need to check that the nylon lines which attach the springs to the lower part of the door mechanisms are in place and this can also be done while the machine is on its back. or by first removing the side panels to access the door hinge mechanisms. If you have a custom cabinet panel on your machine it may be too heavy for the springs and new springs will have to be installed.
Jan 10, 2007 | Bosch 24 in. SGS43C12 Classixx...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
