Question about Dishwashers
The doorlock light has been staying on for about a week although the dishwasher would still work. Now it will not do anything and the Lock on light is staying on except when the door is open. can you nhelp me. Thank you, Steve
    Novelist:
  • 151 Answers
1. Press the Heated Dry pad for three seconds.2. An indicator light next to the lock graphic will
illuminate when the controls are locked.
To Cancel:
( webmaster note: sometimes you need to hold the button in for 5-10 seconds )
2. The indicator light will go off.
SETTING THE CONTROL LOCK:
1. Press the The doorlock light has been - locksymbol.jpg pad for three seconds.
2. An indicator light above the pad will illuminate when the controls are locked.
TO CANCEL:
1. Press the locksymbol.jpg pad for three seconds.
To turn on the lock
Press and hold HEATED DRY for 4-6 seconds. The lock glows. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored.
To turn off the lock
Press and hold HEATED DRY for 4-6 seconds. The light turns off.
Child Lock Controls
To prevent children from accidentally changing the dishwasher cycle or starting the dishwasher, lock the dishwasher controls by pressing and releasing the RINSE ONLY pad (some models) or the NO HEAT DRY pad (some models) for 3 seconds while the door is latched. An indicator light on the lock graphic pad will illuminate when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the RINSE ONLY pad or NO HEAT DRY pad until the indicator light goes out.
press the lock button for more then 10 seconds.if there are no other buttons.
thanks please do rate the solution.thank you for using fixya.keep updated.
Posted on May 28, 2009
Whirlpool Gold quiet washplus dishwasher Red Light staying on--control locked Cannot get it to run, no buttons will do anything
Which model dishwasher do you have? The Control Lock is a feature that keeps a child from starting the dishwasher when it shouldn't run. The Cancel button will work but not the Start button.
On the DU920QWD, to toggle the Control Lock off, press and hold Air Dry for 5 or more seconds. (Holding it again will turn on the lock.) Most dishwashers will have a the Control Lock key labeled with text in a small font for how to enable the Lock. The direct link to the DU920QWDB4 manual is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203376817.pdf .
For other Whirlpool dishwashers, the Control Lock sequence will be listed in the manual. You can get a PDF of many Whirlpool appliance manuals from http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . Enter the model number (from the rim inside the unit) and click on the right arrow.
I hope this helps.
Sep 08, 2011 | Whirlpool Dishwashers
Central locking not working, doors lock then unlock when just want them to lock
one of the door doorlocks is faulty the door lock link switch thinks the door is open and wont allow it to stay locked it can be plugged into the diagnostic socket and that would tell which one is faulty or the slow way is to disconect each door lock one by one until it stays locked then u will no which one is faulty
Apr 19, 2010 | 2000 Ford Focus
My Whirlpool Dishwasher cleaning light stays on
Try unplugging the machine from power to reset the program, if that fails you may need the control panel replaced.
Apr 19, 2017 | Whirlpool Dishwashers
Keyless entry problem to 04 suburban the doors will all lock however the drivers side will not unlock. Last night the passenger door unlocked and I tried manually to unlock from that door and drivers door...
FIRST TRY TO USE LITHIUM GREASE SPRAY CAN ON ALL MOVING ITEMS INSIDE DOOR. AS YOU SPRAY EACH ITEM PUSH AND PULL ON DOOR HANDLE, DOORLOCK PLUNGER. WHILE YOUR IN THERE DO THE DOOR WINDOW GEARS AND MOVE WINDOW UP AND DOWN TOO. SPRAY ALL YOU WANT THE GREASE WONT HURT ANYTHING.
IF STILL DOES NOT WORK REPLACE DOOR LOCK ACTUATOR. USUALLY ONLY 2-3 BOLTS AND 1 CONNECTOR WITH 2 WIRES COMING OFF IT.
Jan 22, 2010 | 2004 Chevrolet Suburban
The PC light on my Miele dishwasher has been on for a few weeks now, although the dishwasher seems to be functioning normaly. What does this PC light mean?
The PC light is actually where the service tech connects his laptop to test your dishwasher - it should be a PC / Salt light. The light indicates that your salt container is empty
Aug 27, 2009 | Dishwashers
04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Jul 16, 2009 | Directed Dei Valet 561r Remote...
Lock light is on
The lock only locks the buttons (childproof), hold it 3 seconds and it will go out.
Jan 18, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
DW won't drain and "lock" light is stuck "ON"
Joe, see if you can reset the board by pressing heated dry-normal-heated dry-normal..(new board). Old board is high temp wash-air dry-high temp wash-air dry. See if it goes back to normal. If not you probably have a stuck or shorted keypad on the overlay..not the board. Catriver...post back
Sep 09, 2006 | Kenmore 15892 Built-in Dishwasher
Dishwashers Logo
109 people viewed this question
Top Dishwashers Experts
Owen Barnes
