Question about LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB
Trouble seeing my lacie drive possible mounting issue
Hello. I really need some help. My 2 big triple 1TB Lacie hard drive will not show up on my desktop. I have tried to repair it in disk utility but, the repair disk button is light gray so I cannot click on it. Also the mount button is light gray so I can't click on it either.  What else can I do??? I have tried changing all the possible settings safe 100, big, fast,jbod. None of these work. I get the disk insertion error which says intialize, ignore or eject. I have about 500 gigs of footage on the drive so I cannot intialize it or I will loose everything. Please help! Thank you, Peggy razbe@mac.com My Lacie drive will not show on My computer even though the drive is flashing and I have tried taking the cables out and rebooting then reconnecting.
  • 696 Answers
It sounds like the RAID controller in the LAcie drive may have failed. When this happens generally the data on the drive is left intact but you will require a new casing for the drives and the help of a data recovery pro to get the files off before you can re-initialize the set. Unfortunately all the good free/cheap utilities work only on single drives so you will need the help of a pro with high level software and additional equipment to retrieve the files.
If you are in North America I would recommend Armor-IT Data Recovery, they're listed in the FixYa service database for most US states. If you're outside North America, post your location and I will help you find an appropriate service.
Chris
Posted on May 29, 2009
I have an old LaCie d2 160GB Hard Drive Extreme with Triple Interface (circa 2005)... I have lost my power cord and I can't seem to be able to find one online to purchase...Does anyone know where I can...
your drive can be used with any D2 or Big Disk power supply as well as some LaCie Porsche power supplies (you need to make sure the connector is the same).
Searching for LaCie Power supply on eBay will give you a few hits that match your needs.
Regards,
Jan 10, 2011 | LaCie (300740) 160 GB Hard Drive
My iMac does not recognize the Lacie 1tb big disk extreme external hard drive. No icon appears.
the first step will be to verify your power supply. When it is plugged to the wall power outlet, it should be silent (no hissing or high pitch noise) and the green light should be on on the power supply.. If it is not the case, replacing it might solve your problems.
Second step is to verify if it is an interface problem. Try using a different port on the drive.
If no success, start Disk Utility and look to the left if you have any mention of a drive of 1TB. If you do, the partition of your drive might be corrupted. You can try running First Aid from Disk utility if its available, else you will need to try a partition repair software or a Data recovery program.
There are a few available that you can get a free copy to see if the data is available before you buy.
Regards,
Jan 07, 2011 | LaCie Big Disk Extreme with Triple...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Upgrade Possible?
Hey Al,
The internal Drive is a standard 3.5 inch IDE 7200RPM unit. you can indeed upgrade this to a 1TB drive as long as it's IDE wether 2.5 or 3.5. Luckily when Lacie was originally offering these drives you could get these in 1TB, so that won't be an issue.
Ciza
Oct 28, 2008 | LaCie (300770) 250 GB Hard Drive
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB Logo
447 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
