Question about Tivoli Model Three Clock Radio
Would like to switch off clock light, esp at night, or even permanently
Would like to switch off light in Tivoli 3 clock. Bright at night!! Did not receive manual with purchase. Thanks David
  • Anonymous Jun 13, 2015
    I snipped the brown wire, sadly for my tivoli (model three) it wasn't the right wire , I should have snipped half way along to make it easy to rejoin, so in the meantime I will just disconnect the harness, (model 3) and just insulate it incase the harness shorts out some other circuit i use my phone as an alarm anyway.
DO NOT CUT ANY WIRES ON THE CLOCK LOOM BUNDLE! (The Brown Wire Is The Alarm Function) EVER!
Unscrew the four corner screws in the rear of the cabinet.
Allow front fascia to slide out to reveal clock back.
Unplug both the clock loom and snooze button loom, this allows the front to lay down.
Carefully unpeel the protective felt on the back of the clock to expose the back cover screws (2), undo.
Lift cover to reveal inner clock and you will notice a small circuit board when the position on the light is...held in by 4 small screws, undo and carefully lift up the board to reveal the LED on its stems.
Carefully cut one and slightly bend (will help restore light function in future). Done!
Carefully reassemble clock and reconnect wire looms...Then carefully make sure all radio function wires are clear of fascia rear end to ***** back into cabinet. Done!
Posted on Apr 09, 2016
  • Alec Cherrington
    Alec Cherrington Apr 09, 2016
  • Anonymous Nov 18, 2016
    I like the light, but on mine it now only works when the radio is switched on. Any idea how to get it back to normal so the light is on all the time? Have tried wiggling the wiring looms to find loose connections and the light does flicker when I do this, but only when the rotary switch for the radio is in the on position - nothing at all when it's in off position.
Would like to switch off clock light, esp at night - 3d848865-4391-4546-8004-9f8c2533f2d0.jpg
Proceed at your own discretion, this will void your warranty. This worked with my Model 3 clock radio:
    1)Remove the four corner screws on the back panel with a long phillips screwdriver.
    2) Do not remove the two other screws on the back panel.
    3)Gently pull the front panel forward, sliding it out of the wooden case leaving the back panel in place. You can pull of the front panel just free of the case and lay it flat before the connected wires are taught.
    4)Unplug the 7 wire harness leading to the back of the clock.
    5)Separate the brown wire from between the black and red wires to make room to cut, or modify it.
    6)The brown wire is the lead wire to the LED light on the clock. To permanently disable the light, cut the brown wire. Better yet, install a switch in line with the brown wire, which I have not attempted yet and is not covered in this fixya.
    Good luck, I have always loved this radio except for the pesky light keeping me up at night.
Posted on Oct 10, 2014
    Problem Solver:
  • 5 Answers
Sell it on ebay
Posted on Jun 04, 2009
Clock light is dim or out?
Sounds like you need a new clock. Parts and repairs cost more than new products.
Apr 11, 2015 | Tivoli Model Three Clock Radio
Dashboard light goes in and out on ford ka whilst driving at night
You mean on and off? Is it random or a constant flash, like a watch or clock? I would try to "clean" the dash light level switch by moving many times from bright level to low level. It may clean the contacts thereby. Otherwise, check connections to that adjustment switch. Or, replace the switch.
Apr 01, 2015 | Ford Ka Cars & Trucks
The display is too bright at night. anyway to dim
Sorry this one was not built with any dimmer opportunities.
Sep 28, 2009 | Starlite Next Play Clock Radio with iPod...
Problems with dashboard lights
The switch that you are talking about... the dimmer switch, must not be working. If you have warranty left, i suggest you take it in. If not, maybe find a good auto wrecker, and replace the switch yourself. I'm guessing they'll be expensive.
Aug 09, 2009 | 2000 Saturn SL
Tivoli model three clock problems
SELL! SELL! SELL! Yup the clock has bit the dust sell er and cut your losses.
May 12, 2009 | Tivoli Model Three Clock Radio
CLOCK NOT WORKING
Time to sell it on ebay!
Dec 17, 2008 | Tivoli Model Three Clock Radio
Back lighting
Funny, I've got one I've just stopped using because the backlight is too bright, even set at its lowest.
Maybe we could trade ;-)
Is your's out completely, or just very dim?
Jan 22, 2008 | Timex T150 Clock Radio
Tivoli Model Three Clock Radio Logo
834 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
KC135Nav
Level 1 Expert
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
