Question about Watts Onan Portable Generator - 5000 , Model# 6500
Onan 6500 male 120/240 plug
Adding a transfer switch to my generator...cannot find out which male plug is used in the 120/240 outlet on my generator...
  • 52 Answers
Northern Tool has a hundred plugs/recepticles. you need to know the amps and volts. just match them to the pictures. or email them a pic of what you need. they helped 3 of my customers with the issue. hope that helps...good luck...
Posted on Aug 30, 2009
I have a 6500 lp onan marquis generator in my rv that wont start. any suggestions?
Check the fuel. If old, drain & refill it.
Check for spark.
If the fuel is there and good, trace it to the carburetor. Check the carburetor bowl for fuel.
Check the spark plug, the magneto, any switch that breaks the circuit or kills the circuit for spark.
If you're getting good fuel to the carburetor and you're getting good spark, try to start it with ether spray.
You might also want to check compression while you're checking everything else.
Jul 26, 2014 | Onan Marquis Gold 6500 Lp
GE Generator 10kw model #040448. TRANSFER SWITCH FAULT message being displayed. Generator works fine. Generator output load voltage = 233V.
This generator has a built in transfer switch. If you do not have an external source of 240 volts going in to the unit (utility power), the transfer switch will show a fault or "abnormal" reading. If you do have utility power going in to the transfer switch, and the generator is on then you have a faulty transfer switch. It is time to warranty or get a replacement switch.
Sep 09, 2013 | Watts Onan Portable Generator - 5000 ,...
Onan 6500 less than 2yrs old and used once. Try
Your air filter may be stuck with dirt or moist. Try to clean or change it.
In all cases the problem is in the air duct, if it runs well without air filter.
Jul 17, 2010 | Watts Onan Portable Generator - 5000 ,...
Need battery for Onan 6500 Generator
I have searched but cannot actually find what type male of battery it uses, other than it is a Lead Acid Battery. Now with lead Acid batteries, it is the actual Capacity, in Both Amperage output, and Physical capacity. So based upon that ANY 12 V DC Wet Cell battery of the SAME Physical size, and CURRENT capacity will work. Look on the actual battery itself, it WILL/Should have identifying marks written on it. Get one the same, it is NOT all that critical.
May 23, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a 1984 winnebago motrhome with a 6500nh rv onan generato runs getting power on the line but none in the motorhome
Hooked in to motorhome via automatic switchover, or does the power plug of motorhome have to be plugged in to receptacle at or near generator?
Mar 15, 2010 | Watts Onan Portable Generator - 5000 ,...
Rv generator output, yet no power in coach. Called Parallax about Transfer switch, yet company says just reset the transfer switch, did now says error fault relay switch. Parallax ats501 why now there is a...
Check to see if you have power going into the switch. This can be done with a voltage meter at the terminals were the cable runs into the transfer switch. Do you have power at the generator plug?
Jan 06, 2010 | Watts Onan Portable Generator - 5000 ,...
Cannot get generator to shut down, please
run a wire from the plug to theframe and put a switch inline and that way when you turn the switch on it will ground out the plug
Nov 12, 2009 | Watts Onan Portable Generator - 5000 ,...
Lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Jun 05, 2009 | Watts Onan Portable Generator - 5000 ,...
Converting the power to genertor
You should not have to switch between battery and generator, unless you are trying to use an inverter as well. Batteries are 12vdc, typically run lighting, water pump, furnace, fridge controls. Generator powers ac, microwave, television, and anything else that plugs into a 120vac wall outlet. Inverter may also run select loads, and possibly dedicated wall outlets, but not AC, fridge, or microwave (usually).
Most RVs / Motorhomes now have automatic transfer switches that will switch between the generator, shorepower, and possibly an inverter. Your coach is made during an era of transition from manual transfer switch (in form of heavy duty electrical outlet near shore power cord) and the automatic transfer switch.
There is no specific place where a transfer switch or generator receptacle are mounted on an RV. There are no rules or regulations tha cover this as far as I know. Your RV may also have an EMS (Energy Management System) that will control the transfer switch as well. EMS panels are typically located above the refrigerator or above driver / passenger seats in overhead compartment.
Apr 06, 2009 | Watts Onan Portable Generator - 5000 ,...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Watts Onan Portable Generator - 5000 , Model# 6500 Logo
193 people viewed this question
Top Watts Electrical Supplies Experts
Jim London
Jim London
Ottoniel
Joseph Hoffmann
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
