Question about Sony -Ericsson OEM HCB-300 Bluetooth Handsfree Car Kit Headset
'Yellow Wire - Stereo Connection???'
Where specifically does the yellow wire connect? Is it to the speaker wires behind the head unit, the power wires, etc.? Can this only be used if you have a mute option on your car? Will I run into the same issue if I purchase the advanced mute wiring kit? niether one of these solutions answered the question... I also have the hcb-30 unit and the same questions.... Can this only be used if you have a mute option on your car? Will I run into the same issue if I purchase the advanced mute wiring kit
  • 1 more comment
  • wheelsgodown May 28, 2009
    No... havnt installed it yet, the yellow wire is supposed to go to the stereo to mute the radio when the phone rings,,,, but I dont have a "audio mute" input on my stereo.... If I get the advanced mute setup they have it intergates it into the car speakers but does it also take care of muting the sound too?
  • Samuel Charles Spriggs May 11, 2010
    It sounds like the mute kit just switches the speakers from one source to another or just disconnects them. So, I would say, yes, that would mute the sound.
    The yellow wire is often for a power antenna -- but not always -- there should be a label somewhere.
    The system is working, you just have an extra wire -- is that correct?
Yellow wire connects to the music mute wire on the back of the car stereo (usually brown). This will mute the stereo when the hands free is in use!
Posted on Aug 10, 2009
I HAVE POWER TO TO MY SWITCH ON MY DEH150MP BUT NOT TO THE FACE PLATE
so you have 3 wires that make the stereo turn on red is trigger from when you turn the key whatever wire turns active on the cars wire harness that needs to be conneced to the red wire on the head unit. yellow wire need to be connected to the cars wire harness that has constant power on even when the cars key is in the off position. Last connection should always be the ground connection should be made when connecting a stereo unit. You can use the ground off the cars wire harness or you can make your own ground using a sheet metal screw and tapping into the cars sub framing behind the unit with a loop connector at the screw end and a barrel connector to the stereo end. Them 3 wires red ,yellow,and black are the only 3 wires that need to be connect to turn the unit on and off. If your stereo doesn't hold its memory on the settings everytime you turn the car off you have the red and yellow wire crossed and you would need to swap them. goodluck
Mar 27, 2018 | Car Audio & Video
Toyota Camry 2003 V6 radio
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 16, 2016 | Toyota Cars & Trucks
Wiring diagram for 2004 toyota 4runner with jbl
It appears that red is a speaker connection and not power. The complete wiring diagram I'd in the link below.
speaker wire color Toyota 4Runner Forum Largest 4Runner Forum
Jan 26, 2014 | Toyota Cars & Trucks
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
If you can help me i need to know if it is possible to wire a amp into a 2002 landcrusier stock headunit cheers
yes, there is an amp turn-on wire from the head unit (black with a red stripe). You will need to add a power wire and fuse from the fuse box to run the amp. You can use the speaker outputs as inputs to the amp, depending on what you are trying to do. Please let me know if you need more help, and identify the amp model as well as the speakers you will connect.
Car Radio Illumination Wire: Black/Red
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: Under the center console.
Right Front Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Yellow
Aug 27, 2011 | Car Audio & Video
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
How do i install a wharfedale CD head unit into a daewoo lanos 01
Please see THIS TIP for generic head unit wiring, and also the following Wire chart for your Lanos....
2001 Daewoo Lanos Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Dark Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Brown/White
Right Front Speaker Negative Wire (-): Gray
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue/Black
Right Rear Speaker Negative Wire (-): Yellow/Dark Green
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 03, 2010 | Car Audio & Video
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Rear Speakers Size: 6 1/2′
May 21, 2009 | 1992 Saturn SL2
Someone gave me a Pioneer DEH-2700 head unit and didn't have any of the manuals. I have a 2007 Chevy Cobalt How to I install this unit into my car. I don't know which wires go to what or anything
the easiest way to solve this issue is to buy a wire harness for your car this will make the install alot easier. Its already color coded for your wires, so head out to your local installer or try best buy you might also need a stereo kit. Email me with questions on installs. jerree_cardenas2006@yahoo.com
Jul 25, 2008 | Pioneer Car Audio & Video
Radio Communications Logo
378 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Rob Beech
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
