Question about Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine
I have an old Singer 478 and I can't get the needle to grab the bobber thread. Is there a special trick for this one? i`m not sure what brand sewing machine i have but the bobbin thread will not feed up towards the needle when i turn the wheel
  • 111 Answers
Your machine threads from front to back. make sure the flat side of the needle is facing towards the back of the machine...
Posted on May 29, 2009
I have a singer 31K 20 that won't pick up the bottom thread can anyone help please?
Install a brand new needle and confirm it is installed correctly.
Changing thread brands may be helpful. AVOID old or bargain bin threads. Focus on spending a bit more for better quality thread.
If it still does not work, it could be the machine is out of time. Search for sewing machine timing or take it for service.
May 21, 2017 | Singer Sewing Machines
Top thread not grabbing bottom thread
Be sure to use a brand new needle--old, bent/damaged needles will not pick up bobbin thread.
If that does not resolve the problem, most likely the machine is out of time. Search sewing machine timing or take it for service.
Dec 28, 2016 | Sewing Machines
I have just been given a singer melodie 40.When I start to sew, material is stopped by bobbin? Bobbin is breaking off bits of thread underneath?
Try a brand new needle. Make sure the thread is suitable to the needle and fabric you are using. AVOID old or bargain bin threads. Spend an extra dollar or two for good thread.
All About Needles
Check that there are no loose threads stuck in the upper thread path, ie the tension disk.
ALWAYS RAISE the presser foot when threading the upper thread. Verify that the thread path is correct. Mis-threading will invariably cause broken thread.
Clean out the bobbin area & feed dogs of any lint and loose threads. Check that the bobbin has been installed & threaded correctly and turning the right direction in the bobbin case.
Manually rotate the handwheel one turn until the upper thread grabs the the bobbin thread. Pull it the rest of the way to the top. When beginning to stitch, start slowly and gently hold both thread tails in your left hand until it has made a couple of stitches.
How and Why to Bring up the Bobbin Thread
If you have a manual, make sure you follow the maintenance tips. If the machine needs oiling, be sure to follow the instructions using only fresh good quality sewing machine oil. Most machines that have been given as gifts from a sewist's stash may not have been maintained regularly.
If it still does not stitch properly, take it for service. It could have a timing issue, ie the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
Singer melodie 40 user manual
Oct 25, 2016 | Singer Sewing Machines
The needle on my Singer 99k does not face sideways but more at the 20 past position on a clock. It sews ok on most heavier fabrics but the upper thread shreds on light fabrics.
If the thread is shredding, it is usually an incompatibility of the needle, thread, and fabric. Try a different type of needle and make sure the needle's eye is large enough for the thread.
All About Needles
Also, it helps to avoid old/fuzzy or bargain bin threads. Stick with new and better quality thread brand names, ie even Coats & Clark sometimes plays havoc with sewing machines. Also, some machines have an incompatibility with certain thread brands, so you may need to experiment.
NOTE: it is strange that the needle does not sit straight in the needle holder. This could also be causing a problem since the thread is twisting as it penetrates the fabric and not fitting into the needle's scarf like it should.
Jan 25, 2016 | Singer Sewing Machines
Needle wont move singer 478
I have a Kenmore sewing machine. I'ts about 30 to 40 years old. I have never had a problem with it until today. The needle got stuck down where bobbin is. I don't know if it should be seen by a pro. I can not get the needle out. The Bar on the side will not move either way. help...........!
Jul 06, 2013 | Singer Sewing Machines
Singer sewing machine pulls fabric and snarls
try changing the needle--make sure the needle is the right one for the
fabric being sewed.
rethread the machine using every thread guide
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint
you may also have to use a washable stabilizer with the fabric
Apr 15, 2013 | Singer Sewing Machines
Singer ingenuity 7436 needle wantpick up the bobber
a. needle in backwards
or
b. needle threaded wrong
Apr 23, 2009 | Singer 7436 - INGENUITY
When you turn the handwheel, does the hook move? If not the top gear on the vertical shaft is stripped and needs to be replaced.
Jan 31, 2009 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine Logo
324 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
