Question about KitchenAid Refrigerators
Doors are hot...changed condensor motor, but still not working
Changed condensor motor, because it did not come on whem compressor worked..and the doors started to get hot. but the new motor doesn't work either. is there an other possible problem and where is it located?
    Guru:
  • 1,524 Answers
Trouble with the "Adaptive Defrost Control".
Posted on May 28, 2009
The compressor on my rls175 gets hot is this normal
wHEN A COMPRESSOR GETS HOT AND STAYS HOT NOT NORMAL, AND IS USUALLY THE RESULT OF OVERWORKING OR STRESSING THE COMPRESSOR? DUES TO EITHER LEAVING THE DOOR OPEN TO LONG TO MANY TIMES. A BAD DOOR SEAL, BAD THERMISTORS OR COLD CONTROL, OR A DIRTY CONDENSOR FAN AND COMPRESSOR OVER WORKING THE SYSTEM, ETC
Sep 23, 2014 | Hotpoint Refrigerators
Why is my refrigerator cutting off for 15-30 monutes?
Compressor is tripping on thermal overload(it's hot!). It is possibly hot from running with a dirty condensor, make sure the condensor is cleaned. Some refrigerators have a big grid type coil on the back and some are located underneath where the compressor is and cooled by a fan motor. If it has a fan motor, the motor may have failed as well. If condensor needs cleaning I suggest taking it outside and washing with hose.
If the refrigerator has a refrigerant leak, it could cause the compressor to overheat for a few reasons as well.
Compressor lock up is another possibility, could be caused by loss of refrigerant( which would cause a lack of oil/ or lack of oil returning from the system back to the compressor. Compressor would have to be changed and leak located or repaired. It usually is cheaper to just buy a new fridge
Jun 19, 2014 | Refrigerators
Bottom freezer really hot to touch where door shuts
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
May 22, 2012 | Whirlpool Refrigerators
The strip between the two doors of my whirlpool refrigerator model ed5ntgxlt00 hot to touch the fridge side runs at 60 degrees the freezer side runs at about 33 degrees plus the compressor is hot to touch
May 21, 2012 | Whirlpool Refrigerators
Where door meets gets very warm/hot
May 19, 2012 | Kenmore Side by Side Refrigerator
Metal band between doors on refrigertor is hot
May 15, 2012 | Kenmore Refrigerators
Sub zero 642 refrigerator not cooling
Being a sub zero tech and actually fixing that exact model earlier today I would recommend you call a qualified service tech to come take a look. If not, I'll tell you the steps I would take to isolate the problem. 1) check to see if the refrigerator fan, also called the evaporator fan, is running. Just open the door, hold in the switch next to the light switch and listen. You'll hear it easily if it is. 2) If fan is running remove the grate up top, the one you took off to put the condensor fan motor, and see if the right side compressor is running. Don't always go with if its vibrating its running because the freezer compressor or the condensor fan can cause it to happen. Find the high side, or condensor line which is the smaller that comes out of the compressor in the back and runs up front to the condensor, and feel if its hot. Hot = good, cold = bad. Note that all this can be avoided if you have a set of freon guages because that model has access taps already on them. They are wrapped in yellow. If you have guages unscrew the cap and connect the guages. On the outside numbers the needle should be around the 25-30 on the positive side. If its in the green area, the negative, around the 10 you need some freon, and possibly have a micro-leak that needs repairing. If its down in the -20 to -30 area you have a serious leak, more than likely in the evaporator inside the fridge, and you should relay call a tech. Now if the needle jumps way up to 70 or 80 and the compressor is hot, really bad, call tech. and if it does that and is cold, the compressor is just off. Now if your still with me and stuck through this far i'll give you the cliff notes.
If the temp is 55 that mean the fan inside is running, and that more than likely the compressor. Now here are some questions to ask yourself. Are the condensor coils clean? That would raise the temperature. You just changed the condensor fan motor, did you put the blade back on right? If the air flow is blowing across the compressor in the direction of the freezedr compressor, your blowing really hot air from the condensor across the compressor and your temperature will raise badly. Fan draws air across the compressor and through the condensor. Worse case scenario you jacked the control board up inside, which I dont think is the case either. ** check that fan blade **
Apr 29, 2012 | Sub-Zero 642
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
46 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
