Question about Dryers
Dryer heats up but the drum wont turn--drum turns manually
Whirpool imperial series dryer heats up but the drum does not turn
    Problem Solver:
  • 5 Answers
Belt has come off or broken
Posted on May 29, 2009
MY WHIRPOOL IMPERIAL SERIES DRYER WONT START. MODEL # LEN2000PWO...WORK LAST NIGHT.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Dryers
Whirpool dryer, no heat, timer is not going right
no heat and the timer not operating is an incoming power problem,shut off and reset the breaker or check both fuses at the power panel in the house,the element needs 240volts a.c. to heat and the drum motor that turns the clothes is on one side of the 240volts which will be 120 volts a.c. and the timer is on the other 120 volts a.c.,if you lose either phase either the timer or drum motor wont turn and for sure it will not heat up,also check the neutral terminal wire inside the dryer for burning off as it carries all the return current from both phase power wire,if this opens tho it will only heat and no drum or timer operation
May 29, 2011 | Whirlpool LER4634J Electric Dryer
I have a whirpool dryer that is not heating model number wed5550sq0 Imperial series. I took the heater coil off. is that the only thing it could be?
On the heater element housing is 2 limits.
If either of these are open the dryer will not heat but it will run.
More Here
May 18, 2011 | Whirlpool Dryers
I have replaced the heating element in the dryer and started it but still no heat, the drum turns and there is air flow but no heat, its a whirlpool imperial series dryer
Check the breaker in your home. Turn it off then back on to be sure there is 240 VAC going to the dryer. Often times one side of the breaker will trip internally and even though it looks like it is okay, it can be tripped. Be sure to turn it off then back on.
Kelly
Mar 24, 2011 | Dryers
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Mark
http://www.fixya.com/support/t6322596-get
Jan 19, 2011 | Whirlpool Dryers
Turns on but doesn't heat up
most likely heating element needs to be replaced.most can be accessed by removing back panel. also a thermostat switch may be faulty.
Aug 09, 2009 | Dryers
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer heats but the drum doesn't rotate
There is usually a large belt that goes around the drum to turn it ...it is either fallen off the motor pulley , broke .....or the motor may be gone in it ....not sure if there are any fuses for the motor on your dryer .
If you can tip the dryer over the bottom is usually open and you can see the motor and belt from there
Jan 09, 2009 | Kenmore 64952 Electric Dryer
Electric Whirpool Dyrer Wont Run
your dryer needs a new motor
Sep 17, 2007 | Dryers
Dryers Logo
156 people viewed this question
Top Dryers Experts
