Computer runs very slow when more than 2 WINDOWS are up and running and an IM program is running.
If you ctrl-alt-delete and view processes in task manager you might try to isolate anything that may be running in the background and using up alot of your RAM. It may also be indicative that you have some type of malware; maybe try to run the freeware programs spybot or adaware and remove any virii found.
If you want new RAM it looks like you need to go for PC2700 DDR SDRAM DIMMs; your computer can hold a maximum of 2 GB.
You may find some RAM on eBay for relatively cheap; if you want it new I would goto memorystock http://www.memorystock.com/memory/CompaqPresarioSR1110NX.html
Good Luck!
184-pin DIMM : DDR PC2700
recommended from crutial
Memory expansion
4 Sockets / 400Mhz DDR
Max minne
4GB
Memory std.
256MB-1 GB (Removable)
MODULES
MUST BE ORDERED AND INSTALLED IN PAIRS for Dual Channel mode. If 4GB is
installed, the recognized memory may be reduced to 3.5GB or less
(depending on system configuration and memory allocation). Models with
"-b" are bundled with monitors.
