Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio Washer Error message code F1
Our washer gets an "F1" error message when it's got 17 minutes remaining in the complete cycle. any ideas? Cliff We had the dreaded "F" errors and I called Whirlpool after reading these postings. Was first told the machine was out of warranty so they couldn't help. I mentioned the multitude of similar problems on the Internet and insisted on speaking to a supervisor. After a short wait, I was told they would provide the part for free, but labor was on me. I said that wasn't acceptable, and again asked to speak with a supervisor. After another short wait, I was told they would cover all parts and labor. They sent the authorization on Thursday, the service tech called Friday, and was out on Monday (which was Memorial Day.) He couldn't order parts until Tuesday, but got them Wednesday, and installed them Thursday. Everything now appears to be working well. Just be persistent with Whirlpool.
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$@%^
Posted on Sep 21, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I have a Whirlpool Cabario. I keep getting an error code of F1. I hit cancel and then start several times and it resets itself and continues. The same thing happens when it is about to start the rinse...
    Hi
    Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Oct 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio top loading washer F1 Error
    F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
    Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
    I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
    Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
    On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
    1. Disconnect the power
    2. Gain access to the back of the ERC
    3. Disconnect the ribbon cable that connects the ERC to the touchpad
    4. Check nothing will short when power is reconnected
    5. reconnect the power and switch on
    6. Watch for F1 and listen for the beep
    7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
    8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
    Feb 13, 2009 | Whirlpool Washing Machines
    WRONG POWDER'S, TO MANY POWDERS IN PUMP PUT ONE TEASPOON OF OIL IN WHERE THE POWDERS SHOULD GO AND RUN CYCLE AND THAT WILL DESROY THEY SUDS AND ONLY USE HIGH EFF DETRG. FROM NOW ON, IF THAT DONT FIX PROBL YOU HAVE SOMETHING STUCK IN YOUR PUMP, YOU WILL HAVE TO HAVE TECH TO TAKE YOUR FRONT OFF MACHINE AND GO INTO PUMP WHICH IS EASY AND REMOVE ITEM, PROBL SOCK, OR UNDYS. I HAD THIS PROBL WITH MINE.
    Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    according to the service manual for the cabrio f-1 means main motor control failure the brain so to speak has a glitch it is intermitten but will eventually fail.
    Jan 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    f1 code means the main control needs to be replaced. pretty common repair
    Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    The following list of codes indicates a possible electronics communication problem with the washer:
    Cabrio washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
    To remove the error display, press Pause/Cancel twice.
    PLACEHOLDER FOR ART
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Please do not forget to rate and comment about your experience with fixya today.
    Aug 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    161 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
