Question about HP DesignJet 1050c plus InkJet Printer
System Error 0B000D 0000000D on display, nothing prints
System Error 0B000D 0000000D This error message is displayed on my HP Designjet 1050C Plus plotter. I've unplugged many times, nothing will print. Any suggestions?
  • Anonymous Mar 26, 2014
    I am getting that error code what does it mean?
    President:
  • HP Master
  • 1,314 Answers
Hello.
From the service manual:
System Error: 0B000D
Problem
Description:
24 V source test failure.
Corrective Action: Replace the Electronics Module
HP Part number: C6072-60146
I just looked up the pricing and it's not cheap. Let me know if I can be of further assistance.
Posted on May 28, 2009
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
Dont' replace the electronics module! Thats a rip off. You need to check for the resistence between the transistor pins, the transistors read 3055V, the transistors that are bad will read zero resistence, they are on the main circuit board towards the left hand side near where it reads scan axis motor. There are four of them, usually 2 of them short out and then it blows the white little 10amp surface mount fuse in the top right hand corner of the board. Need to solder on new transistors and fuse. Fuse is made by littlefuse..
Posted on Sep 03, 2012
  • 1 more comment
  • chromajoe Nov 26, 2013
    I could use a little more direction on the location of the resistors.
  • tximbua
    tximbua May 01, 2014
    you are right.I had the same problem before and solve it the same way.
  • Michael Schaffter
    Michael Schaffter May 02, 2014
    There are no resistors.
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
Designjet 1050c system error 0A0050
0A0050 indicates a leak in the tube system has been detected. Can be caused by condensation, but more likely the tubes are leaking and need to be replaced.
Sep 01, 2014 | HP DesignJet 1050c plus InkJet Printer
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
SYSTEM ERROR CODE 04C300 C8CC0000 THEN STOPPED PRINTING MIDWAY THROUGH JOB iT SAYS TO HIT ENTER TO CONTINUE BUT GOES INTO A LOOP OF ERROR CODE /HIT ENTER, ETC
This is an IO error. Remove the back cover and disconnect the cables to the HDD and remove the JetDierct card. Print the internal test page. If it prints OK, install the Jet Direct card. Print again. Prints OK? Replace the HDD (or run without it). Does not print OK?
Replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Dec 16, 2009 | HP DesignJet 1050c plus InkJet Printer
Check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Sep 10, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
Error code showing on my HP 1050c plotter
The error stands for : 24V source test failure.
And i'm sorry to say but the service manual then tells you to try the following:
- Replace the scan-axis motor assembly.
- Replace the paper-axis motor assembly.
- Replace the service station assembly.
- Replace the main pca.
- Replace the ISS pca.
- Replace the power supply unit.
- Replace the electronics module.
(only replace one component at a time)
Yeah then you have to guess which part to start with.
Maybe anybody else on this forum knows more about the error and has a better idee about the part you should start with.
Just take a good look at the machine, and check which sections of the start up works before the error is prompted.
e.g. If the carriage moves then you could say that the scan-axis motor is probably ok.
Good luck....
Sep 07, 2009 | HP DesignJet 1050c plus InkJet Printer
System Error 060308000008 on HP Designjet 1050C plus
that error show a problem with the pintheads
Remove ALL the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly, if that dont solve the problem change printheads, if after that have the same problem call HP, was a hardware error.
Apr 30, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
1,416 people viewed this question
Seeker5211
Seeker5211
