Question about Microsoft Xbox 360 Console
Flashing red lights
When i turn the xbox on there are flashing red lights and a screen pops up saying i need to contact someone for this problem
    Problem Solver:
  • 8 Answers
I would open up a ticket. get in contact with them and see if they can fix the console under warrenty. Every xbox 360 has a 3 year warrenty i believe. If its out of warrenty it cant hurt to ask how much it would cost.
http://support.xbox.com/support/en/us/nxe/kb.aspx?id=907534&lcid=1033&category=hardware
I am almost certain if the problem isnt the power supply which should still light green when you power the console on. its going to be the CPU/GPU thats poped out a little from high temperatures which stresses the solder joints. hopefully if this is the error you have you may be able to fix it.....
you can open the xbox and bolt the heatsink down tight. so the cpu/gpu has no option but to sit in place google red ring of death and you will find alot of great step by step guides with pictures showing how to fix this hardware fault.
dont listen to anyone recommending you should overheat the console wrap it with towels or anything that sounds stupid simply bolt it down and fingers crossed it works
hope this helps!
Posted on May 28, 2009
I have 3 red lights what is the problem !!!!!!!!!!
Three red lights on the ring of light is an indication of a hardware failure
Here are things to try:
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Apr 05, 2009 | Microsoft Xbox 360 Console
Red light system error
When someone say that his/her Xbox is having 3 red lights problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Jan 25, 2009 | Microsoft Xbox 360 Console
Flshing red light
It needs the 3 red light fix. We can fix this for you contact us at xbox360fixer@verizon.net
Jan 03, 2009 | Microsoft Xbox 360 Console
One red light appears no picture
hello sir
Solving Your Red Light Flashing:
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
Dec 22, 2008 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
3 flashing red lights
it is the ring of death it costs money to repair
Aug 26, 2008 | Microsoft Xbox 360 Console
Red light on original xbox suggestn servicing required
I can help you fix your xbox but i need the service code number in the top corner of the screen suggesting servicing. You can email me at c_a_messmer@hotmail.com
Aug 26, 2008 | Microsoft Xbox Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
An error message comes on screen when thew xbox 360 is turned on as well as it says up the top (system error .contact xbox customer support )also three red lights flash on and off
This is either an error code or the 3 red lights of death. If it is the 3 red lights, and not an error code, you will be under the extended warranty. If it is an error code, hope u are under your origional warranty.
May 09, 2008 | Video Game Consoles & Games
3 flashing lights
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
For more things to try check here
Nov 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
