Question about GE Refrigerators
Wont make iceis it the watervalve
Wont make ice was told it is probally water valveand my water line is not clogged or froze
    Guru:
  • 1,524 Answers
Take the connector off the water valve and test the connector for voltage.
Posted on May 28, 2009
What, other than clogged filter, causes water flow blockage in Whirlpool ED25TE?
FYI - Mine actually froze the water in the line.. had to remove the water filter, turn off the ice maker, pull the fridge away from the wall..remove the line from the fridge connection..laid it outside for a few hours until I could blow through it.. re-installed ..all ok..
Jun 08, 2017 | Whirlpool Refrigerators
How can I clean the water dispenser in my refrigerator? Also the water line is clogged or something.
Bleach water and lots of it .water line may be froze or got a knink in it .try a stiff wire being pushed thru it .
Aug 30, 2015 | GE Refrigerators
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
No water is geeting into ice tray for making ice
The most likely cause is the solonoid controled one in two out watervalve. Even if the water dispenser is working, this would be the most likely cause. You can find this valve be following the water line into the refrigerator. The first place it connects is the valve.
Jan 01, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Our kitchenaid french door with water/ice dispenser has stopped dispensing water. Ice is coming out just no water.
It could possibly be a bad side to the watervalve, or the line going inside the freezer door is frozen.
Jan 06, 2011 | KitchenAid Refrigerators
All of a sudden I can't get water from the door also no water is filling for the ice so I have no ice
You can try replacing the water filter, if that doesnt work it is either going to be a bad watervalve or there is a frozen water line inside the unit
Jan 06, 2011 | LG LFX25960ST Stainless Steel French Door...
New (3 days old) Kenmore Elite refrigerator model 795.7103 with ice maker. Water supply line to the ice maker immediately froze up so won't fill tray to make ice. Serviceman came out and melted ice...
First of all, your freezer should be much lower than 38 degrees. For the ice maker to even work proplerly it has to be below 10 F. Some models have a heater that goes around the fill tube to keep that from happening, but in my opinion, if its only three days old, take it back because it's much too soon for that problem to be occuring.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 10, 2010 | Refrigerators
Sce275 wont harvest runs and makes icewhat causes this problem this has a new pump and watervalve installed thanks
You float valve may be stuck open. Even slowly letting in water will keep the machine from making a good cube. I also belive the uses a flote switch to send it into harvest so if the water level does not go down from making ice it will not go into harvest.
Hope this helps
Apr 20, 2010 | U-Line Icemaker
Water in fridge
First, empty freezer and fridge. Unplug and leave door open for at least 3-4 hours. Blow out drain lines with compressed air. It is more likely that the drain line is clogged than frozen; but a clogged drain line will freeze-up quickly.
Aug 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
