Home | iLO | -3200 32 in. LCD Television | ILO LCD Color HDTV doe...
iLO -3200 32 in. LCD Television
Problem for iLO -3200 32 in. LCD Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
By nightlife47m on May 28, 2009
I can't get the TV to respond to anything other than on/off. I have tried from the side buttons and from the remote. I can turn it on and off but no menu, +/-volumn,+/- channels, entering channels by numbers....none of the buttons on the remote do anything except the Power button. It comes on and reads ANALOG TV as usual then identifies the Channel A 47 with the word Mono underneath.... It plays the channel just fine but that's it..... just that one channel.... Then last thing I recall having done was gone into the TV Menu and set the channels... Could I have screwed something up there? Is there a way to reset the thing back to factory defualts? i have a zenith conciere and cant get to menu nor change channels
Popular Solutions for iLO -3200 32 in. LCD
Questions and Unsolved Problems for iLO -3200 32 in. LCD
Do you recommend iLO -3200 32 in. LCD Television?
Answer
Answer
the tv will turn on and has a good picture but i cannot change the channel or cgange the function or... (More)
Answer
I can only turn the TV on but won't change ch. or vol. nothing will respond remotely or manually.... (More)
Answer
i have an Ilo 32 HD, it can be turned on and off w/universal remote, it is stuck on channel 3, will... (More)
Answer
There is no code for ILO TV in my universal remote code list. I went through the process of letting... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For iLO -3200 32 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
