Question about Refrigerators
Wont make ice
Hello i was told by a few different people and ge my ice maker is not making ice and one told me put water in the icemaker if it dumps ice it is most likely the water valve does that sound correct
  • 63 Answers
More likely a frozen water line in the freezer compartment. Thaw out the freezer completely - then it should work after cooling down again.
Posted on May 28, 2009
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
Dec 20, 2009 | Refrigerators
Ice maker don't make ice
Pour about 2/3 cup of water into the ice maker . If it dumps the cubes but doesn't refill with water , replace the water inlet valve , behind refrig , where the water line connects to on the refrig .
If it does not dump the cubes , and the cubes stay in the ice maker , replace the icemaker .
Oct 13, 2009 | GE Refrigerators
Icemaker
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
thumbs up
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I poured water into the icemaker and ice cubes are formed but will not be dumped into the empty tray of my ge profile
The icemaker is bad then . It will have to be replaced by removing 2 screws and a plug connector . Easily replaced . Make sure the icemaker is turned on though .
Aug 16, 2009 | Refrigerators
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker wont make ice
Put about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If the ice stays in the icemaker , replace the icemaker . Also , make sure the fill tube to icemaker is clear of ice and the coils under refrig are clean of dust , lint , etc..
Aug 12, 2009 | Roper Refrigerators
Ice maker does not work
Make sure fill tube is clear . Pour about 1/2 cup of water into icemaker . If ice dumps but no water into icemaker , replace water inlet valve . If water stays in icemaker , never dumps , replace icemaker . Make sure the coils are clean of dust , lint ,etc...
Aug 05, 2009 | GE Refrigerators
Ice maker
So you are not getting water to the ice maker? If not then fill ice maker with water. If when the water freezes and the ice maker dumps then the water control valve on the back of the refrigerator is defective. Let me know, Sea Breeze
Jul 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge icemaker problems GSS25LSWASS
What part was installed?
Ensure that the Ice Maker arm is in the down position.
There is a thermostat that closes when the ice mold reaches a temperature that indicates that the water in the mold is frozen if this thermostat is faulty it will prevent the Ice Maker from going into the dump cycle.
Hope this helps.
Mar 14, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
