Question about Sony PSP (Piano Black)
Black screen when i press menu on psp
My psp gets a black screen when i press the menu button and i have to turn it off and back on
  • 502 Answers
Sometimes it's a short on the MB itself, sometimes a defective button bar. If you want to repair it yourself, start with the screen, it's a much cheaper part - there are free PSP repair guides that show you how to take it apart.
Posted on Jun 13, 2009
  • 31 Answers
Maybe because it has an internal problem on the screen or in the buttons, if that is the case it is need to be repaired, know the nearest sony repairing shop, only the experts can help you regarding to the internal parts of the psp. thanks!
Posted on May 29, 2009
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
When i try to run a iso/cso game, the white psp would shoe up and then the screen truns black went back to the psp menu and it said Game could not start 80020148 my psp's system software is 5.00 M33-4
What you need to do is disable the umd from within the custom firmware menu. Completely turn off the PSP (hold the power button up until it turns off). Then while holding the right shoulder button, turn the PSP on. The recovery menu will load. Select configuration and then disable the "no umd" option. Exit from the recovery menu and insert a umd disc into the PSP. Make sure auto start is also disabled in the PSP menu settings. You should now be able to run your game.
Hope this helps and thank you for using FixYa
Jan 06, 2011 | Sony PlayStation Portable (PSP) Console
Hi i want to ask how to downgarde psp 6.20 to 5.50 without pandora battery please help me in that...thank you
Hi
You can downgrade your psp without a pandora battery but you will need a Lumines game hack,Follow these steps to do so.
Download the 5.50.pbp file. Rename the 5.50.pbp file to "UPDATE.PBP." Connect your PSP to your computer with the USB cable and select "USB Connection" to place the PSP into USB mode. A window will appear on your computer and you will be able to see the PSP memory stick files.
Download the downgrade pack. Open the "MS_ROOT" folder from the downgrade pack. Right-click the "PSP" folder and click "Copy." Go back to the PSP memory stick and right-click it. Click "Paste" and "Yes" to overwrite the data.
Right-click the UPDATE.PBP file that you downloaded in step one and click "Copy." Open the "PSP" folder on the PSP memory stick and you will see the "GAME" folder. Open this folder to reveal the "UPDATE" folder. Right-click the "UPDATE" folder and click "Paste" to transfer the update file to your PSP memory stick. The downgrade pack and 5.50 update file are on the PSP memory stick. Press the "O" button to safely disconnect the PSP from your computer.
Insert the Lumines PSP game into the PSP drive. Select the game from the PSP menu to start. Press the "Start" button when you get to the Lumines start screen. Your screen will blink red and will turn completely blue. You will be brought back to the PSP screen. It is important to not press any buttons before you get to the Lumines start screen.
Go to the game section of the PSP menu and you will now be able to see the "x.yz update" application. Select it with the "X" button to start it. Press the "X button from the main menu to start the downgrading process. Press "X" again to reboot the PSP when the downgrade has completed. You have now downgraded your PSP to 5.50 firmware.
Jul 31, 2010 | Video Game Consoles & Games
How do i connect my psp to my dsl internet
follow this steps:
Connect your DSL modem to your wireless router. Take an Ethernet cable and connect it from the "Out" port from the DSL modem into the "In" port of the wireless modem. Turn both the modem and router on and let them connect to each other.
Step
Turn on your Sony PSP by sliding the power button up until the PSP screen turns on. Navigate to the "Settings" part of the PSP menu. All of the settings are located on the left side of the PSP menu. At the bottom of the PSP settings menu is an option named "Network Settings." Select that.
Step
Select "Infrastructure Mode" and then "New Connection" from the next screen. Select the "Scan" option and your PSP will look for the nearest wireless connections. Select your router from the list. Your router will be the strongest signal available, and will match the name of the router manufacturer.
Step
Select "Easy" on the next page for the "Address Settings" and save the settings. Press the "X" button to test your connection, and you will connect to the access point. Press the "O" button to exit the settings menu. You are now connected to the Internet with your DSL modem.
Feb 02, 2010 | Sony PSP-3000 Black Console
How do i reset my whole psp? even if it wont turn on
Hi there, Please turn off your psp. Before it turns on please hold on "R button". After that you will see a black screen. Please choose configuration, then choose "VSH MENU" (it should be enabled). Choose exit afterwards. Automatically your psp will reset. It will reboot.
From then you can have your psp reset anytime your psp was on. Simply push "select button" and choose reset. That's it!
Dec 14, 2008 | Sony PlayStation Portable (PSP) Console
PSP turned on, black screen, cannot access recovery menu
Your psp screen may have broke you can buy a repair or get it fixed at ebay.com.Type in psp repair and you will see people will fix them for a low cost.
Nov 10, 2008 | Sony PlayStation Portable (PSP) Console
Flicker and very slow
turn off your PSP ,then switch on again.. when the screen are in black condition "press R button" and change the CPU speed
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
My psp has no image but it has sound
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
or'
If the LCD screen suddenly turns dark
  • Check the Backlight Auto-Off setting
    If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on.
    To check the Backlight Auto-Off setting:
    1. From the XMB™ menu, go to icn_settings.gif (Settings) > [Power Settings] and press the icn_btnx_color.gif button.
    2. Highlight [Backlight Auto-Off] and press the icn_btnx_color.gif button.
    3. Select a time interval and press the icn_btnx_color.gif button to save. Select OFF if you wish to disable this feature.
  • Check the Auto Sleep setting
    If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on.
    To check the Auto Sleep setting:
    2. Highlight [Auto Sleep] and press the icn_btnx_color.gif button.
  • Check the Display Button
    Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen.
    The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
Aug 15, 2008 | Video Game Consoles & Games
Psp
(to turn off properly the PSP, hold the "ON/OFF" button for mostly 10secs or more) Usually, when you turn on your PSP while holding the R Trigger, it should go directly to your Recovery Menu (black screen with configuration menus, etc...). If it doesn't do that while holding R, maybe there' s something wrong with your PSP... but if it does, to turn your WMA on, got to recovery Menu>Registry Hacks, then your will see there the options...for activate WMA, Activate Flash player, just press X on those and it should be fine...
Jul 30, 2008 | Sony PlayStation Portable (PSP) Console
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
Feb 06, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
