My pc gets struck up suddenly forcing me to restart (windows xp
Hanging problem of the pc: My system suddenly getting hanging again i have to done restart but some times the problem is getting start before loading the windows, please advice me what to do
  • 90 Answers
Sounds like either a RAM or HDD issue. First thing is if you have 2 sticks of ram pull one out and see if it boots ok if not pull the other stick out and put first stick back in. If neither stick lets you boot then I would run a HDD test (some have them in bios) if you do not have it in bios boot windows into safe mode with command prompt and in command prompt type chkdsk /f
Posted on May 28, 2009
All of a sudden my system will hang with nothing function... not even ctrl+alt+del... mouse is also not working... since having no idea, I have to restart it again and again... This will happen...
This sounds more like a hard drive problem than motherboard. Try this FREE program called Mydefrag click the link. This program works different than the std. windows version. It can move files from a dead spot on the HD to a healthy spot and prolong the loss of your stuff. I would suggest you start moving files to another HD keep things you want or need. Hope this helps FixYA up.
Aug 13, 2011 | Intel D845GVSR Motherboard
Windows Vista Start up problem, reboots automatically.
Boot to recovery console using XP CD, run CHKDSK /R and see if that resolves.
If no go, try a reinstall of windows, if still no go, then replace HDD
Sep 28, 2009 | Dell Inspiron 1525 Notebook
I have the same problem
check to see if the CPU is connected to ur motherboard securly and check RAM aswell.
Jun 06, 2009 | Intel D845GVSR Motherboard
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Some service process not kill in Windows XP
Well you have to get in and use system restore to that point when you had'nt installed the freeware tool and on the prompt that a restart is required for the changes to take effect, chose next time windows is shutdown, which means you dont have to reboot the client machine, but it will be executed the next that machine is switched off by the user.......sodeep
Apr 15, 2009 | Microsoft Windows XP Professional With...
MY PC STRUCK UP STARTING OF WINDOWS
hI SATYA, WRITING 2 SOLUTIONS THAT WILL WORK.... 1. START>>RUN>> IN RUN TYPE FOLLOWING COMMAND LINE. MSCONFIG 2. BY THIS YOU WILL GET SYSTEM CONFIGURATON UTILTIY. CLICK ON STARTUP TAB... AT RIGHT CORNER YOU WILL GET DISABLE ALL. CLICK ON THAT IT WILL ASK TO RESTART SYSTEM. AFTER THAT YOU WILL FEEL YOUR SYSTEM IS TAKING LESS TIME.
Aug 30, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
