Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Wireless router (SMC) install problems
Wireless router install almost successful but at the end of program cannot find connection
  • onunotaner Mar 12, 2008
    Simply doesn´t end the wizard. Fine till the 3º step and then... "cannot establish conection". Plain simple. Like the the meaningless opinion: reset and restart router. My question is... What can i do? Return this estoic equipment for another brand?
    Novelist:
    Champion:
  • 244 Answers
Hi muchie,
Please kindly post additional further details regarding your router problem as follow:
1.) Are you assigning static IP on your router?
2.) What Operating System you used on your computer browsing the internet?
3.) Are familiar with DHCP?
Hope you can provide the following question in order me to find right solution you need. Please kindly be specific in stating your problem and please don't used summarization statement it is really hard to understand what's the meaning of sentences.
I am here waiting to help you.
Best regards,
Philip
Posted on Oct 24, 2007
  • Cheater Cheater Nov 02, 2007
    The last thing you to do is to get hummer then used it to broke your router maybe this very helpful to you..
    Problem Solver:
  • 5 Answers
Reboot the wireless router and the computer and go to wireless network and put in the security code for wireless
SOURCE:
Installing SMCBR14UP printer with wireless connection
Let say you had Win7 then just select "add a printer" after look for 'devices and printer" in the Start section.If you find a printer there just delete it and then "add a printer" and follow the wizard.Note thta it will be wireless so try the IP you use in the Mac PC.
Jun 17, 2012 | SMC Barricade SMCBR14UP Router
I used to have a simple cable modem (coax cable in, network cable out) connected to a separate Linksys wireless router, model WRT400N. This worked beatifully. To improve download speed, I recently...
Welcome to FixYa!
For you to be able to do that, you will need to set the SMC router to bridge mode, you will not be able to do that by yourself because only tech from your ISP have the capability of doing that since they have this tool that can operate on the router setting it to bridgemode. Basically, you will need to call your ISP to set the router to bridgemode and from there, you will be able to configure the linksys router.
Hope this information will help.
Your response is very much appreciated. Thank you for using FixYa!
Jun 24, 2011 | Linksys WRT400N Router
I have installed a SMC2862W-G wireless usb adapater on my pc. it is recognizing my wireless router and it is showing a decent signal strength in the SMC utility. However, my wireless connection icon on my...
You need to install the driver disk that came with the USB adapter. Your PC correctly pointed out that the internal WI-FI adapter is not working but the USB adapter should be showing on the taskbar of the driver is installed correctly.
Mar 08, 2018 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
Hi
Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
Hope this helps
Dec 09, 2010 | SMC Barricade 7004VWBR Wireless Router
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
SMC Barricade wireless router needs to be reset constantly
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Feb 18, 2009 | SMC (SMCWBR14-G2) Router
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Wireless wont connect
Hi, I have found a link that may help you set up your system. http://portforward.com/english/routers/port_triggering/routerindex.htm You don't say what the setup error is? I think the "Help Link URL" will show ya how to reset the router, so do that.. set up the SSID and Channel and, then go to the lappy & set up your Wifi for "Client"mode, as ya should have set up ya Router as an "Access Point" ensure that is all set up correctly. below is a link to a program Wireless Mon, install this on the Lappy, and use it to see if your "Wifi Router" is actualy transmitting etc...and prove ya wifi in lappy is OK.. G L. http://www.bestvistadownloads.com/download-signal-strength-software.html
Aug 05, 2007 | SMC (SMC7004AWBR) Router
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
370 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
