Question about Kitchen Ranges
Hi there, we have replaced dual infinite switch on our jennair range and cannot figure out the correct wiring for the new 12002125 switch....can you help...???
  • 19,396 Answers
Follow the instructions below from partselect:
Attach the black wire(s) from the old switch (terminal 2) to the new switch terminal P1. Also attach the jumper cable to P1 and "jump" it to S1.
Attach the orange wire (old switch terminal 5) to S2
Attach the yellow wire (old switch terminal 4) to 4a
Attach the tan/(white?) wire (old switch terminal 3) to terminal 4 on the new switch
Attach the single red wire from the right front element to terminal 2 on the new switch.
Attach the 'compound' red wires (the ones that come from the left rear/outlet connection and is also attached to the right rear switch) to terminal P2 on the new switch.
There is no need to separate the compound red wires.
hi there,
Best regards.
G.
Posted on May 28, 2009
Frigidaire glass top stove dual element ony works on high no matter were knob is set
Hello Chad;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have a bad Warmer Infinite Switch.
Once installed, the switch controls your gas range's warmer drawer element. When replacing your gas range's switch, consider replacing its knob (PartsDirect part number 316442403) if it shows significant wear.
To replace your gas range's warmer infinite switch, pull the knob off the switch and remove the screws securing it. Disconnect any wires running to the switch and take note of those connections. Remove the switch and put the new one into its place, reattaching the wires to the same terminals. Be sure to unplug your gas range before beginning the repair.
25433033-yqd4wkymfcifmtxqtu0sd2am-5-0.jpg Part #: 316095500 Cost: $32.00
It is located on the right hand side of your display panel. You have to remove the side panels screws and control panel back to access.
Feb 15, 2015 | Frigidaire Kitchen Ranges
Hello. We have a Whirlpool Accubake range and we heard a pop and saw a spark under one of our 8" burners. What ever happened tripped the circut. After resetting the circut, the rest of the oven and...
I had a problem with my Whirlpool range. It would not regulate temperature properly on the two large 8" burners. I found the problem was the "infinite switch". The infinite switch regulates temperature of the electric stove elements.
I found this video (see youtube link below) informative and it solved my problem. I found the correct infinite switch on Amazon (my infinite switch was this $21.00 one: https://www.amazon.com/gp/product/B004XLEJ7M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The fix to replace 2 infinite switches (both 8" burner switches) took me 1 hour, including cleaning the floor under the stove (nasty!). All was well afterward.
https://www.youtube.com/watch?v=F4gCWNdu2io
Apr 14, 2017 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
I have a Jenn-Air cve3400 cooktop. The dual radiant burner doesn't work properly. The inside portion of the burner doesn't work by itself or in tandem with the outside portion of the burner. Is it the...
I just went thru this problem. There are TWO possible switch replacement parts. one is 12002422 and was my correct replacement number.
12002125 was the WRONG part..would not work no matter how you wired it. the failed switch being replaced was part number 7403p406-60. 7403p851-60 will NOT work.
my serial # was 12284711qz
call Jen air customer support and give your serial # and switch part # to get the correct part and diagram... Jenn air changed parts and wiring in the middle of a run.
Aug 14, 2010 | Cooktops
How do I replace a broken dual infinite switch on my Amana AKT3040SS ceramic cooktop?
raise cook top out of counter and remove screws holding glass top to base . remove glass and on the right is switch bank two screws holding each / remove and do not pull wires. but transfer one at a time noting that markings on old sw match new . . sw pt # is 12002125 and cost 49.35. and reinstall in reverse.. hope this helps . and do turn off the power before you start. mm good sailing .,
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
New heating element pops circuit breaker
Obviously something is shorting out. Check all wiring.
Oct 31, 2017 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Just replaced infinite switch part # 12002125 on Jenn-aire JED8430 cooktop. Now burner will only come on HIGH and does not cycle.
Hello- First of all, congratulations on getting it out, apart, and back together again! There are two types of switches for this cooktop. One for the dual, other three are single. Wires can be a trick sometimes. Replacement switches look different sometimes, but work the same. If part is correct, check wire connections at contact points. Lightly crimp any loose ones. Partselect.com has the wiring diagram for JED8430.  Let me know if this info helps- have more if needed. - Thanks- ED
Mar 05, 2010 | Kitchen Ranges
Infinite Switch on Amana Stove
I would start with P1. The "P" terminal is for the "element on" indicator light on the panel. Start with P1 then turn on that element and check the light for operation. P2 is most likely a loop through. Hope that helps.
Oct 31, 2008 | Amana Kitchen Ranges
How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Sep 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
Infinite Switch Replacement
one switch cant affect them all check for a central power problem low voltage weak breaker loose wires on cord loose terminals in outlet box etc.
Feb 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
257 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
