Question about Dell OptiPlex SX270 PC Desktop
COMPUTER GOES ON THEN SHUTS DOWN
Hi I have a dell optiplex sx270, it was working well untill one day on putting it on the fun goes on , the led lights at the front go on and then it goes off immediately. the light on the motherboard is always on, I have tried plugging it out and back no change.
  • 1 more comment
  • maxwelotieno May 28, 2009
    I have tried disconecting everything and then back. at some point it refused and then worked again for three hours when i switched it off and left for a while coming back same problem.
    I have tried disconecting everything and then back. at some point it refused and then worked again for three hours when i switched it off and left for a while coming back same problem. and the screen shows nothing, it goes off immediately, the fun just works for a sec and then everything goes off.
  • bradhscherer
    bradhscherer May 11, 2010
    Try disconnecting everything not necessary including soundcards, cd/dvd drives and hard drives. This sounds like a videocard or hard drive issue but we want to eliminate everything.
    Do you even see the bios screen flash on?
    Does your monitor show anything when it first turns on?
    Will it boot to a cd?
    Do you have a boot disk?
    Does that work when everything is disco'ed except the CD Drive?
    Is there any beep sequence?
    Is the video card onboard or add on? Can you try the HD in another PC?
    Can you try the video card in another pc?
    Thanks,
    B
  • 63 Answers
This could be a heat issue but more likely hardware. You need another pc to start testing out the parts individually. That is the only way to verify for sure what is going on.
Posted on May 29, 2009
  • 90 Answers
I would say this is a hardware issue. nothing anyone online can do for you with this type of issue unless you recently chaged something.
Posted on May 28, 2009
Optiplex SX270 LED light code
Hello
The LED code you described indicates a memory failure. Remove and re-install all of your memory. If this does not fix the issue, remove all memory and insert one stick at a time until the unit turns on. Replace faulty memory.
Here is the LED Code guide from Dell...
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408
May 01, 2010 | Dell OptiPlex SX270 PC Desktop
Won't turn on - power led comes yellow & blinking
Please perform the steps mention:
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. Good Luck.!!
Aug 27, 2009 | Dell OptiPlex SX270 PC Desktop
I have a dell optiplex sx270 version PC.I had shut it down ,as we had a holiday the next day.I later tried to switch it on after my holiday .But it won't switch on .However the power adapter indicator...
it seems like the power button is at fault i doubt it will effect your data unless you pass it to a bad repair man who may erase everything your hard drive is a seperate entity and can be removed for backup
Aug 06, 2009 | Dell OptiPlex SX270 PC Desktop
DELL SX270 WILL NOT COME ON HAVE LITE INSIDE PC
the power supply is probably bad. It's really hard to tell without a little more information. When my power supply went bad on my computer. the hdd light would come on but nothing else and the computer would not even try to start.the power supply puts out several different voltages with both positive and negative outputs.
Aug 01, 2009 | Dell OptiPlex SX270 PC Desktop
I have a dell sx270 desktop when I plug it in only the fan works
First of all, keep the front button pressed until the system shuts off. It might be one of several causes:
1) Memory module damaged (or dirty)
2) The processor is damaged, or
3) The motherboard parted off.
Remove the memory modules and test them one by one. Or if you can test them in another PC (assuming both PCs use the same kind of modules).
May 01, 2009 | Dell OptiPlex SX270 PC Desktop
Hou do i reset bios on a dell optiplex sx270
  1. Boot up the computer into the setup (depending on your bios, to get into the bios you need to hit the DEL key during boot up.)
  2. Press 'ALT' and 'F' at the same time
  3. Turn 'NUM LOCK', 'SCROLL LOCK' and 'CAPS LOCK' on. (Make sure the lights on the keyboard are on.)
  4. Press 'ALT' and 'P' at the same time. The bios should now be reset to the factory settings.
Apr 02, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
Orange led on mother board
You have a hardware failure, most likely memory or video card. The first thing I would try is open the case and blow the dust out of it, especially dust on the memory modules and anywhere on the motherboard. Then try to boot the computer again. If that does not work I would start removing components one at a time and testing them.
Mar 16, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
My computer will not power on
brand and model of the computer would be good.... as well there is a switch on the back of the computer on the power supply. toggle it to the other position and try again
Robert
Sep 08, 2008 | Dell OptiPlex SX270 PC Desktop
Dell OptiPlex SX270 PC Desktop Logo
164 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
