Question about Honda Maxus Pressure Washer MX5222
Engine runs fine no water pressure
Engine runs fine but water pump woesn't work no pressure
  • Joey Sartain
    Joey Sartain May 11, 2010
    does water come out the nozzle when you pull the trigger? IF so, does it do it whether the engine is running or not?
2 Suggested Answers
  • 13 Answers
SOURCE: Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
Posted on Jul 16, 2010
After the winter my motor runs fine but no water pressure
Did you drain the pump in the fall? Cracked housing or blown gasket.
Apr 22, 2014 | Garden
I have a craftsman 675 pressure washer. It runs fine. But when I turn on the water, it dies. What is wrong with it?
either the engine is worn and has no power or the pump is overloading the engine........
squeeze the trigger before you turn on the water.....
try no high pressure hose to make sure the water exits the pump ok
Sep 01, 2013 | Craftsman Garden
No water flow through system, checked tip, water was on, nozzle on, checked filter. motor starts and runs fine.
The first thing you need to check is if you have the water supply hocked to the mechine with no pressure line connected just the water dose it spray out the pressure line connecter with out the engine running . If this dosen't happen the water pump is no good . You can never start any kind of mechine like this with out constant water flow . It sounds like something is broken between the engine shaft and the pump the pump is likely seized and this broke the connection between the engine and the pump. If this is the case the mechine is likely not worth the money you would have to put into it to save it
Sep 17, 2011 | Honda Garden
Husky pressure washer 80432. 1 year old. worked before the winter. no pressure this summer. honda engine runs fine. replaced the pump from the bottom of the engine down... still doesn't pressurize. ...
Check the inlet strainer where the water supply hose is attached,this is located just inside the coupling where you hook up the water hose.
Jul 30, 2010 | Garden
With pump removed engines runs fine. When new pump is installed it is very hard to pull with water flowing but will not start. Engine was just tuned up late year.
Chances are that your new pump is generating good pressure. Because of this, the engine is trying to turn over against the pressurized system. Try pulling the handle on your wand when pull starting the engine to see if this eliminates your problem.
Jul 01, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Pressure washer - My water blaster does not speed up
I was mistaken in my thinking about how the pressure washer works. There is a by-pass valve that takes the load off the engine when you stop spraying. The engine actually runs at a constant RMP. When the spray is on, the by-pass valve closes and this increases the load on the engine. This is what I had been hearing as a "speeding-up" of the engine and was no longer hearing. Anyway, I took the un-loader apart and blew it out with some compressed air. It works fine now.
Sep 12, 2009 | Garden
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
No pressure from pressure washer
The "dump valve" inside the units pump,not engine is more than likly malfunctioning or bad. Try checking pump oil,buy 30 w pump oil and fill to line also ckeck black cone type turn knob marked +/- and turn to + for increase in pressure,also check water supply hose and if restricted ,unrestrict water line.
Please rate jj505
Apr 02, 2009 | House Brand Garden
Low water pressure
IF ITS PUMPING FINE-( NOT RUNNING, PUMPING ) YOU PROBABLY HAVE A LEAK SOMEWHERE DOWNSTREAM. IS A WELL OR WHAT IS THE PUMP USED FOR?
Mar 14, 2009 | Jet Flo 04325143A Marine Heavy Duty Water...
Honda Maxus Pressure Washer MX5222 Logo
164 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
