Question about Canon PIXMA MP780 All-In-One InkJet Printer
Won't scan today
Normally my machine works great; I've never had problems with the scanner. Today I tried scanning on the glass and through the document handler. When it starts, everything seems fine and sounds normal. Then there's a long pause (way longer than usual) while a pop-up window shows, "Processing calibration data from a scanner. Do not open cover." I see that normally, but not for such a long time. The next thing I get is the following error ScanMP pop up: Cannot scan for these reasons: - The original may not be set correctly - The protective sheet may be put in place - The lamp may not be warmed up (it needs a few minutes for adjusting lamp on low temperature.) Scanner driver will be closed. Code: 2,178,0
I got no help from you. Called Canon USA and got immediate assistance, which resolved the problem. Please don't contact me anyomre. Thank you.
Posted on May 29, 2009
  • soulsong Sep 03, 2011
    I have similar issue with NEW pixma printer scanner .the scanner after all the usual fixes then some!still does not work, still gives the same error. (code 2,155,50 ) reinsntalled it. on off on off. drivers etc etc . . the whole thing. nothing! it starts to scan then part way across it stops and does this..also the stop cancel button does not function at all. there . no help anywhere. i want to number for the USA canon help . maybe they can do sumthing. !!
One side of scan appears super bright to white , like the document is not touching the glass on that side . Why ?
  • Log on to the Lexmark website and update the driver. Also try and run diagnostics and see if that lists a fault.
Jan 19, 2018 | Lexmark P4350 All-In-One InkJet Printer
Scanning Blank
Try and re-install the scanner, check the settings of the scanner software you are using and change the settings to scan picture or scan in colour. Thanks
May 13, 2010 | IRIScan Executive 2 Flatbed Scanner
My Officejet Pro 8500 won't scan, says "no scan options"
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 23, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Lines when scanned
The common solution on this sight to this problem on any copier seemed to be simply clean the glass. I first cleaned the glass on the bed...no help. Then I lifted the feeder and discovered a portion of the glass under that as well. Once it was cleaned the lines disappeared!
I saved $$ on a useless service call for a simple, easy to fix problem thanks to this site!
May 22, 2008 | Canon ImageClass MF5770 Laser Copier...
Scanner
Try scanning from the Kodak AiO Home Center software. If that fails, you should get better feedback. Unfortunately, I have run into this when my ink is low. While it should not matter, is does. Check to see if you need to replace a cartridge.
Good Luck.
DigiChick.
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
If you are using the document feeder, chances are something has gotten on the glass recently. Try cleaning the area of the scanner's glass that is to the left (underneath the document feeder) of the main glass.
Mar 20, 2008 | Ricoh Aficio SP-C210SF Printer
Black section in scans
Check/clean scan glass for marks (small section of glass under lid that runs width of copy glass.
Is lamp dim or dark in one section?
at low res. what is the result?
Nov 04, 2007 | Lexmark X1150 All-In-One InkJet Printer
Ms9520 buzzez and then will not scan
Look at your user's guide on Pg 14, here is a online link for it: http://lib.store.yahoo.net/lib/barcodescannersdiscount/MetrologicVoyagerUG.pdf "Continuous Razzberry Tone with all LEDs off: If, upon power, the scanner emits a continuous razzberry tone, then the scanner has an experienced an electronic failure. Return the unit for repair to an authorized service center." Is the "Razzberry Tone" the low buzzing you refer to(?) Pg 24 has a "Trouble Shooting Guide" take a look at it too.
Jun 06, 2007 | Metrologic Instruments METROLOGIC VOYAGER...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
334 people viewed this question
old marine
old marine
