Question about Acer Aspire 5315 Notebook
Acer 5315 will not start up windows
It goes to the acer screen then goes blank! Any ideas b4 I resort to a d2d recovery?!
  • 8 more comments
  • catherine_r May 28, 2009
    hi, do u mean to start up the laptop with the hard drive out?
    hi, it won't start in safe mode I have tried!
    It goes straight to a screen where it says a few things and no bootable device insert boot disk and press any key
    the recovery will wipe my hard dricve though is that right?
    as in the c drive...so it will reset all the c drive but leave my d drive data?
    thanks so much for your help!
    I will be trying to get the data off the drive first as there is some things i dont want to lose then doing the recovery!
    no problem :)
  • meteshadow May 11, 2010
    try to put out the harddisk and open the laptop. wait for the laptop stays under Acer logo still or it is going and giving a message of error.
  • 489 Answers
Yes . we will see if it is problem with the harddisk or motherboard. if you cant do that when you see Acer logo press alt+f10 to recovery.
Posted on May 28, 2009
  • 3 more comments
  • meteshadow May 28, 2009
    ok your mainboard is good. you need to do recovery. thats all you need.
    only the C part. you will have again what were in D
    yes thats right.
    can you rate this ?
    thanks
  • 90 Answers
Hit F8 a few times after you see acer logo and see if it will let you start windows in safe mode. Short of that not much you can do.
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
I have 1recovery **** named aspire 5610 dvd2 should i have a dvd1 disk also
go to http://www.sysresccd.org/Download
download the iso and burn it to a cd.
boot your computer with it
read the explanations coming up on the screen and when you see that you can choose how to start, type "wizard"
choose the top choice (auto)
when it starts right click on the desktop and start GPARTED.
one of the discs will be marked as "boot"
right click the disc called "recovery" (or the one that is not marked as boot).
choose manage flags
set it to Boot.
press apply on top (not always needed tho)
in the left picture (the one that opened from the start)
type reboot
remove the cd when you see the acer logo again.
the acer recovery manger should start.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
Can i back up my hard drive before doing a d2d recovery?
if your computer can't fully start into windows the way I back those up is use an EIDE/USB converter (should be available in most computer stores) and all you have to do is remove the HD from your laptop plug it into the converter and plug the converter into working computer and pull all the files onto it and do whatever you need with it (ex back it up to dvd etc..)
May 28, 2009 | Acer Aspire 5315 Notebook
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
Possible reset
Acer Aspire 5315 has a restore partition to set it back to factory settings, which will keep your windows intact too, but reset everything like you just purchased it.
First boot up the computer and press F2 to enter the bios, make sure that D2D recovery is enabled. Then exit and press Alt + and tap F10 when the manufacturers name appears for example HP, Tiny, Hewlett Packard etc.. etc.. screen appears on boot. This will open the recovery program. Before you can run the program it will ask you for the password. This will be the password you chose when you first got you laptop. You may have chosen your user name password or left it blank. If you left it blank just press enter, if you did enter a password you will need to remember it, or try the word admin.
Once the system has been restored it will take time running a few checks, so be patient.
Also this will restore C:drive only, so the good thing is anything you have saved on D: drive will remain intact.
I hope this helps.
Nov 17, 2008 | Acer Aspire 3100-1405 Notebook
Erecovery
Check that it is enabled in the bios
Press F2 when you boot and go into bios, make sure that D2D recovery is enabled. Then save the changes and exit, to run the recovery program you need to press Alt and tap F10 on boot when the manufacturers screen appears.
I hope this helps
Nov 14, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 has blank blue screen and will not run recovery disks
Try starting up in safe mode. To do this, press the F8 key immediately after the comuters posts & before windows starts to load. Then scroll to "Use last settings that last worked" & click on it.
Sep 06, 2008 | Acer Computers & Internet
Broken??
If the computer is only a couple weeks old, you need to cantact Acer for technical support under the warranty.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7293&areaid=7&website=AcerPanAm.com/us
Click the ESupport link in upper right corner
Jul 06, 2008 | Acer Aspire 5315 Notebook
D2d recovery
you can not use erecovery and d2d if your don't have the hidden d21 partition on your harddisk. and since you have replaced your harddisk you don't have it anymore.
mail to compurepair and see if he can fix it..
rate me if you want.
CS.
Apr 08, 2008 | Acer Aspire 5630 Notebook
D2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Jan 04, 2008 | Computers & Internet
Acer Aspire 5315 Notebook Logo
320 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
