Question about Dell 1600n All-In-One Laser Printer
Grey arm is in place. cannot find any paper anywher that is a jam
Dell 1600N printer. Error message is "Jam 1 or no cartridge
  • lkreid7 Jun 05, 2009
    Changed the cartridge and it worked!
  • 57 Answers
This can happen if any of the contact points on the cartridge are even remotely scratched or if the cartridge is "low" even if it doesnt say its low
Please Rate Me
Posted on May 28, 2009
Paper jam feed manual and paper goes through 3/4 of the way
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Dell 1600n All-In-One Laser Printer
1600n grinding and jamming
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Dell 1600n All-In-One Laser Printer
Jam msg will not clear ? no paper in path?
when you removed the paper, a small piece might still be stuck somewhere or the sensor might have remained in the on position.
May 19, 2009 | Dell 1600n All-In-One Laser Printer
Paper jam 2 - checked every area - cut equipment off and back on - still paper jam 2 - need service person asap.
there are 4 or 5 sensors through paper road:
1)paper input sensor near input roller
2)margin sensor between input roller and cartridge unit
3)transfer bell sensor between cartridge and fuser unit
4)fusing sensor before fusing
5)out put tray sensor
check all sensors if you can find out and check any paper jam there and check sensor stander at normal position, also check each sensor click ok(the micro switch ok) .
there is any sensor out of work should be showing paper jam.
Jan 23, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600N warming up message
Hi Unplug the printer power cable from the wall and disconnect it from the printer as well. Turn the printer power switch on for 15 seconds. This will reset the printer. Turn the printer power switch off and plug the cable back in on both ends. Then turn power on. The Document Jam error should be eliminated.
Please keep in mind you must check for any small pieces of paper or look for a real paper jam prior to completing the steps above.
I hope that helps.
Sep 16, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n Cartridge Sensors messed up
the cause of this problem is a little spring sited in left side of feed sensor´s actuator and keep it on it´s right position: sensor actuated(off);if this little spring is out of position,feed sensor´s actuator go out of position and machine´s main board detects high(on) signal showing a paper jam message.
May 30, 2008 | Dell 1600n All-In-One Laser Printer
I have dell 1600 multifunctional jam 1/no cartridge
I have been having the same problem. I almost gave up on this printer. After careful analysis I noticed that if I pulled up on the cartridge while it was inserted and held it up (I took the door off and depressed the door closed button w/ a screwdriver) the printer would work fine.
I shimmed the front of the cartridge w/ a piece of rubber or folded up paper. There appears to be something in the back that doesn't make full contact if you do not do this. Now it works fine.
I haven't had any feed problems, but I kept my shim to the front right and made sure it doesn't go too deep.
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
Printer won't print
Your Dell unit is really manufactured by Samsung as SCX-4720F/FN. You face one of two possibilities: (1) a paper sensor was moved out of place, inwhich case you need a technician to open the unit and reattach the sensor. Or (2) have you opened the door that located to the back of the unit?
Sep 13, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
164 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
