Question about Singer Sewing Machines
The part to holds the bobber doesn't move
I need your help. The part that holds the bobber does not move. What do I need top do to fix the sewing machine? Any assitance would be greatly appreciated. Thank you.
  • 111 Answers
Stripped lower gears...
Posted on Jun 01, 2009
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
Putting bottum bobber back together brother vx-1140
sewing machines don't have bobbers. Bobbers are for fishing.
Dec 10, 2012 | Brother Sewing Machines
My casket where the bobber sets is loose and comes out. When I try to place the basket where the bobber sits it is too high and the lver will not close. Is that part broken or how do I put it in properly?...
I have a similar Singer with a drop-in bobbin and there is a little trick to getting the bobbin holder in correctly. When you put it in push it forward (under the feed dogs) then pull it back (toward you) before you release the spring that holds it in. Test it to make sure it doesn't come out then insert your bobbin per your user manual.
Sep 10, 2012 | Singer 7462 Mechanical Sewing Machine
The needle wont stayed treadedwhile sewing. I have changed out the needle and changed out the thread and it keeps unthereading while sewing the bobber is working just wont stay threaded threw the neddle
My trouble shooting suggestions are:
check that the thread is in the thread take up lever eye correctly
Is the top tension set too tight, ie should be on 5
Is the thread catching somewhere in the thread path?
Is it catching on the thread spool itself, sometimes they have a little notch cut in the top edge to hold the thread tail but it could be getting caught in there during sewing. If so, turn thread spool up the other way or use a mushroom cap on top to hold the thread off the spool top edge.
just go through the top threading path checking thread is into all thread eyes correctly and not catching on anything and that it is threaded correctly, it should be one of the above causing this.
Jul 10, 2011 | Brother Sewing Machines
Bobbin thread won't come up.
I had a received a sewing machine and it was doing the same thing.
I brought it to a sewing place to get it checked out.
They said the timing is off and they fixed it bought it cost me $68.00.
Rose
Apr 28, 2009 | Singer Tiny Tailor TT700
Singer ingenuity 7436 needle wantpick up the bobber
a. needle in backwards
or
b. needle threaded wrong
Apr 23, 2009 | Singer 7436 - INGENUITY
I have an old Singer 478 and I can't get the needle to grab the bobber thread. Is there a special trick for this one?
When you turn the handwheel, does the hook move? If not the top gear on the vertical shaft is stripped and needs to be replaced.
Jan 31, 2009 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Threading bobbin on singer6268
Have you tried placing that half screw and or plug you found on top of the bobber compartment where it belongs: Normally underneath the bobbin compartment cover , at-top the bobbin case closest to you and your left..normally there will be a screw there to keep the bobbin and the bobbin case where it belongs, while it is doing it job.. at least thats how most of the sewing machines i have used or see or worked on have been.. Good luck.
Aug 30, 2007 | Sewing Machines
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
