Question about Refrigerators
Beaumark fridge freezer is going on and off
We have a 7 yr old Beaumark fridge and even on the coldest fridge setting the freezer may or may not kick back on..then very noisy for about an hour..then it works fine for a week or so and then the same problem. Is this a fixable issue or is it time for a new fridge? It is a frost free fridge but, all this up and down temperature puts ice in most of the freezer food.
Laura
    Problem Solver:
  • 18 Answers
Check the condensor coils for dust, try to see if the condensor fan is blowing air over the coil, check inside the freezer to assure the inside fan is circulating air, and if the "noise" is coming from either of the fan motors, they will need replaced by a service technician.
Posted on May 29, 2009
  • Nuage10 Feb 15, 2011
    My Beaumark 31491-1 is seven years old and the fridge fails to cool sufficiently because the fan gets block in ice build-up on the coils. This is the fifth time in 7 years. Now I am told that all of the styrofoam insulation must be replaced and not sure the right part can be ordered.
I have a Fridgeadaire MTRF322 F/F - 7 yr old. The thermostat in the fridge clicks in when I turn to 7. I then turn down to 3 - 4 as per instructions. The fridge gets cold, even ices on the back but then...
While on holiday, leave it on 7. When you get back, get the thermostat changed, but only after checking the following:
Condenser grille clear and clean, all fans working ok, defrost freezer and recheck fridge, check door seals properly, try setting at 5 or 6 and see if the freezer is better able to hold temperature
Aug 07, 2012 | Refrigerators
I've had a Samsung fridge for 6-7 years, it's a small/medium fridge/freezer with the freezer at the top (sorry, don;t have the size handy). The freezer works fine, however the fridge no longer makes...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung Refrigerators
Fridge/Freezer both only cool and not cold/freezing
have you checked the rear wall of the freezer?if its frosted over,remove the rear panel to check the evaporator coil,if its iced-up it cannot cool the unit properly,if so de-ice with a hair dryer,then check the defrost heater under the coil that is suppose to keep the coil ice free,if its open it cant heat to defrost,if it has continuity and is good,then check the defrost control be it timed or adaptive for proper operation
Jul 18, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge/freezer not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Does not stay cold. Even with
Sounds like the compressor, or a refrigerant leak. Being a year old I would call Frigidaire and try to get it fixed or replaced under warranty.
Jan 03, 2010 | Frigidaire FRT21H8 Top Freezer...
Noisy refrigerator/freezer
The freezer fan motor , being noisey , is probably the cause for the food/drink problem . It should be replaced . Pt # 54482-10 is the part number for the motor . However , on your model , it looks like the bottom freezer panel , has to be removed , to replace the motor . The motor costs about $70.00 . Do not know if you should try this yourself , may need an experienced repairman , to remove the divider strip , to remove the panel .
Oct 11, 2009 | Refrigerators
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Whirlpool intgrated fridge/freezer is not keeping
7 is coldest. but how cold is the freezer? all cold is made in freezer. ma be developing a frose problem
Jul 06, 2009 | Whirlpool ED2GHEXN Side by Side...
Refrigerators Logo
366 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
