Question about Xerox Phaser 6110MFP All-In-One Laser Printer
Scrunched paper My Phaser 6110 MFP is scrunching up paper in the vertical bit at the back after it has left the paper tray. Does anyone know what to do?
How old is the printer? It sounds like the rubber rollers have gotten hard and no longer can pull the paper through the vertical as quickly as the tray rollers do. I had a similar problem with a LaserJet4 printer and I had to obtain a repair kit (available online) and replace the old parts. Hope this helped.
Posted on May 28, 2009
Paper is coming out scrunched (folded) and sometimes torn at the top left corner.
Make sure the printer is clear of any paper jams and don't load the tray full of paper, load it 75% full but not 100%.
Feb 28, 2011 | HP LaserJet 3380 All-In-One Printer
LEXMARK x 2650 -- PAPER WILL NOT FEED INTO PRINTER CORRECTLY- WILL STOP AND SCRUNCH UP ON THE LEFT SIDE OF PRINTER FEEDER
Look very carefully inside where it scrunches up. you'll probably see another small piece of paper from a previous jam... remove it
Jan 23, 2011 | Lexmark Office Equipment & Supplies
Have a Phaser 6110 MFP. When I scan a page using the ADF I get 3 color lines running vertically down the image. If I don't use the ADF, the page scans without the lines. What could be causing this?
There are some small spots on the "seal" glass. It is the 3/4 inch wide strip under the scanner, not the main glass. Clean that strip well, I suggest taking some rubbing alcohol and just a regular piece of paper, crumpled up. Use that to clean that strip vigorously.
That will take care of it.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
My canon printer scrunches the paper on the right side
you may have a bad or off set roller you can try to callibrate it but more than likely it needs internal repair! good luck!
Dec 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Scrunches up paper, wanta different pper
This is a possible solution as I had the same problem on a PSC 1510. You will need to rest the printer on its fron edge after closing the paper tray. With the bottom of the printer facing you you should see a small removable panel on the left hand side - it has one Torx screw in the upper left corner. Undo that screw and the panel can be removed - be careful not to dislodge the felt ink pad. Once the panel has been removed you will see a black plastic lever which pivots in a socket with one long arm extending to the right and a shorter arm extending down. Remove this arm and then reinstall it making sure that the small peg on the shorter arm sits in the long vertical slot of the black plastic slide inside the printer. Once you have done this the long arm should be close to horizontal. Replace the removable panel - making sure the felt ink pad is in place - and the problem should be solved.
I hope this helps.
chasmith
Apr 24, 2009 | HP PSC 1510 All-In-One InkJet Printer
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Paper Jam at exit
This happened with an old HP Laserjet 1100A of mine.
I had apparently dropped a screw in the paper-out slot and it was jamming the paper on just one spot.
As you know, the entire sheet is connected, so It is most likely a similar situation in which a previous jam has left a small wad of paper under one of the rollers, and this is preventing the paper from exiting the slot.
Best bet, print something and see where the paper is scrunching up. This is most likely the roller that has the paper stuck under it. Remove the toner block and blast some compressed air into the spot the jam is most likely originating and see if anything else flys out.
Also, if that does not work, you might try manually rotating the rollers backwards, which will often eject the lodged paper chunk.
Note- Please be careful inside the printer! Do not touch the bright green drum, or anything that dosen't look like it is rubber and rolls paper around!
It is very easy to mess things up in there ;)
Sep 28, 2008 | Samsung CLP 300 Laser Printer
Hp laser jet 1020 paper jam and not printing... half paper inside of printer
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
Dec 27, 2007 | HP LaserJet 1020 Printer
Xerox Phaser 6110MFP All-In-One Laser Printer Logo
139 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
