Question about Philips GOGEAR SA6045 MP3 Player
Product will not turn on,only when i plug in a usb chord, it will update then turn off.
My Phiillips GoGear will not turn on at all. When i hook it up to the computer it doesnt even respond. I know it's not just mine because my sister has one just like it and the day after we bought them hers did the same thing. So she took it back and got another one and the second one is doing the exact same thing. :( HELP!!
  • 57 Answers
I would suggest to hold the play/pause button, then hold the switch on button for a moment. Ideally it should boot into recovery mode. Now click the "Clean Up", and then "Reboot". If that fails, try to reload the firmware again.
Posted on May 28, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
Now frustration has set in as i am trying to get my Yamaha MU5 tone generator and Korg keyboard (Both midi) to link with my new Acer Aspire One D255 N550 netbook which i have loaded with an old version of...
I need to know how it's all hooked up first (IE Korg midi out to Yamaha in, Yamaha thru or out to Chord, USB from chord to Acer.....etc etc. etc.)
Also, see if the instruments can at least talk to each other.
Post a reply here.
Mar 14, 2011 | Acer (54.AA806.001) Sound Card
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
Error 0xd05d010d and continously beeping sound.
1) disconnect the USB cable from the back of the printer, Without turning off the product
2) Remove the cartridges from the product.
3) Wait for the 'Insert Cartridges ' message to display on the control panel. 4) Disconnect the power cord from the back of the product. 5) press and hold the power button for 30 sec 6) release the button and then plug in the power chord. If the product does not automatically turn on, press the Power button 7) Reinsert the cartridges, and then close any open doors on the product 8) If you receive a prompt to print a calibration page, do so check what happens if still you face the same issue follow the steps below.. 9) unplug the power chord from the back of the printer.. 10) Press and hold the (#) and 6 key together 11) without releasing the button plug in the power chord.. 12) after the power chord is pluged in release the button.... 13) If you receive a prompt to aligne do so check what happens.. if it does not work try with a different set of ink cartridge... still if you face the same issue you u replace the printer...
Jan 25, 2011 | HP Officejet 5610 All-In-One InkJet...
My gogear will only turn on for a second and only if the charger is hooked up
plug usb in and go to "my computer" right click on philips drive and select format click ok dont change any options.this does work i have same one and have done it.
May 31, 2009 | Philips GoGear SA5285/37 Digital Media...
Windows Will not detect my Philips SA6045 4gb mps player
Whenever i cannect it ,nothing comes up,nothing in "my computer" to click on.I update the driver for it,it works for about 20 seconds,then the device becomes unresponsive and i have tp update it again,which again it will connect for a short time ,become unresponsive,and then the update process.How do I keep my MP3 Player Connected.Also nothing is wrong with my USB chord.
Sep 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips Turns Back Off
Install and run the Philips Device Manager from the product CD.
Switch off the player.
Press and hold [VOL+] whilst connecting the player to the PC.
Device manager should report device error.
Follow on-screen prompts.
This should format the player and re-load the system files.
Apr 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Cant connect to usb port
the connection to your gogear will be smaller than the usb to your pc, it's the same with all peripherals, you should have been supplied a cable with it, standard usb one end and a thinner or squarer conection at the player, see below for examples http://www.directusbstore.com/cnb/shop/directusbstore?op=catalogue-products-null&prodCategoryID=55
Sep 13, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
154 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
