Question about Maytag MSD2756G Side by Side Refrigerator
Can't unlock my ice dispenser
I need the combination to unlock the ice and water dispenser on the front of my Maytag side by side Does not work for me? Any one know why?
2 Suggested Answers
SOURCE: Can't unlock my ice dispenser
press the lock button three times in a row
Posted on Apr 06, 2009
Maytag mfi2568aes control panel
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
May 16, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
How to unlock water dispenser
ther is no unlock . need a better understanding of the problem to help .... if no water or no ice there several ans . to the prob. if no water to disp but it does make ice then look at the water valve .. mm hope this helps // feed back pls //
Jul 10, 2011 | Maytag MSD2756G Side by Side Refrigerator
Unlock water and ice machine
OK from what I understand for some reason ice and water appears to be locked. This information is in the service manual for your model but also results in test that you will need to do there at the dispenser control. It will be listed on page 108 of manual and section 2-8 of the manual. I will assist you if you like, Sea Breeze
Mar 24, 2010 | Maytag MSD2756G Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Can't unlock ice water depenser on maytag side by side
On most brands all you have to do is hold the lock button until it unlocks.
Jun 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
How do I get the filter light off after changing the water filter?
PRESS THE LOCK AND LIGHT BUTTONS AT THE SAME TIME UNTIL LIGHTS BLINK.THEN IT WILL RESET FOR 12 MONTHS OR 44O GAL.HOPE THIS HELPS
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Feb 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
May 15, 2008 | Maytag MSD2756GES Side by Side...
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag MSD2756G Side by Side Refrigerator Logo
95 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
