Question about Nintendo Wii Console
No Wii Menu during initial boot
My Wii boots normally with the screen asking you to press the A button, but after you do, the Wii Menu never comes up
    Problem Solver:
  • 14 Answers
Hmmmmm.... Call Nindendo up and tell them. Their number is 877.586.6895
Posted on May 28, 2009
Cd start server primergy b210 fujitsu siemens
In order to change the boot drive you have to change the boot settings in BIOS, or sometimes you can get a separate boot menu which allows you to change this setting on a one-off basis. During the boot sequence you need to press the "F12" button during the POST testing to bring up the boot menu if one is available, otherwise you need to press the "Del" or "F2" button during the POST process to bring up the Bios screens. Navigate to the BOOT option and alter the boot sequence, save the settings, exit BIOS and reboot.
Feb 18, 2014 | HP Compaq ProLiant ML110 G4 Server
Get out safe mode
During the boot up, press F5 for a boot menu, or press F8 for an interactive boot. Either way you will get a scrolling screen of loading device drivers and such so don't be alarmed. After that completes you should be at a menu where you can select a "'normal boot". Let it load and finish, then reboot pc to see if it's operating normally.
Oct 12, 2013 | Lenovo Computers & Internet
How can i exit safe mode on my toshiba laptop
Click the "Start" button.
Type "System Configuration" (without quotes) in the search box and select "System Configuration" from the search results.
This will open Microsoft's System Configuration utility.
Click the "Boot" tab.
Clear the "Safe Boot" check box under "Boot Options."
Using the Windows Boot Menu
Turn on your computer.
Press the "F8" key repeatedly immediately after the BIOS screen appears.
The BIOS screen typically displays the logo of the computer manufacturer.
Select "Start Windows Normally" from the boot menu and press "Enter" to proceed.
or
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Nov 02, 2012 | Toshiba Computers & Internet
It crashes and asked me to reinstall it when I did that now it will not install at all.
If the problem lies on Windows this can be repaired. First, If you are using Windows 7 or Vista, we can try to launch startup repair from the advance boot options menu. You can access this through tapping F8 right after you turn the computer on. Tap F8 until you get to the advance boot options menu. Choose "Repair your Computer" and this should guide you on how to do the startup repair.
If you are using Windows XP, we need to try to boot to safe mode and see if you can boot the Operating System from there. To do this, it's the same drill, tap F8 repeatedly on your keyboard once you turn the computer on until you get to advance boot options menu. Choose safe mode and press enter. This should load the operating system to safe mode. If you are able to boot from here then that means one of your "drivers" has failed the OS to boot normally. If all of these fails, We can try to repair the Operating System by booting using your Restore CD or your Operating System CD from the CD-ROM drive. Reboot the computer and press F12 (or whatever it is that makes you choose to boot to CD) while seeing the pc manufacturer's logo, this should give you the options to boot to CD-ROM. It will give you a quick prompt of "press any key to boot to cd..". Make sure you press the space bar during this time to initiate the boot from CD-ROM.
For Windows XP, Once the Windows Setup loads, Choose "Recovery Console" to repair your computer. Just choose the installation you would like to repair (normally it's number 1) then it will ask you for the administrator password. By default, the password is blank, but if you set a password for admin then use that password.
Once you get to the prompt, Type this command. "CHKDSK /R" (without the quotes). It will initiate the repair for your OS. This might take an hour or so. Just wait for it to finish and it will automatically reboot your computer. Let the computer computer reboot normally. You should be able to get to your normal windows screen back.
For Windows 7 and Vista, do the F8 and choose Repair your Computer, Choose the installation you want to repair then choose command prompt. Type CHKDSK /R and that shoudl initiate the repair for your OS. Most of the time, the "startup repair" should do the fix for Vista and 7, but just in case it fails, do this step.
BTW, these repairs are designed to repair the OS without you losing the data you have on the pc.
Hope this helps. Good Luck.
Aug 22, 2011 | Computers & Internet
When i start the laptop, i want to go in to the setup. however when i press F2, it ask you to insert password.
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT. Click Restart when prompted. Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps don
Feb 26, 2011 | Computers & Internet
I have an IBM ThinkVision 20" L200P LCD monitor. The OSD (On Screen Display) is corrupt and showing garbage characters. I believe it needs a factory reset to re-initialize itself but I cannot find...
Alternate:
or
Hope this helps don't forget to vote
Feb 18, 2011 | Computers & Internet
I do have a dell laptop, but last night it hangs up den i cannot turn it off already so i'd just let the battery empty, i recharge it wen i woke up in the morning den it says the computer was not shut down...
I second what computus suggested, but I believe you'll have to press F8 repeatedly during boot instead of ESC or Del button. Boot up in safe mode and it should be able to restore things :-)
Aug 13, 2010 | Dell Inspiron 1525 Notebook
I tried to re-install windows xp to clean my computer (running slow). It aske if I wanted to include web updates and I answer yes. Computer went to a blank screen and no won't load from recovery disc or...
Hi, you will need to reformat your hard drive before installing XP, First boot into BIOS by pressing the F1 key during bootup, change the primary boot drvice to CD rom, save changes. Insert XP cd into drive and reboot PC; select boot from CD when this appears during the initial boot fase. Allow files to be installed. When this finishes, delete partion and then repartion hard drive. Select format hard drive, when this completes your PC will reboot, do not select boot from CD and XP will start to install normally.
Hope this helps, if not come back to me.
Aug 04, 2010 | Computers & Internet
How to get into boot menu ( settings)
hold escape and f1 at the same timewhen you get to the first part of the startup (before the windows loading screen)
Mar 07, 2010 | Toshiba (P000274520) for Portege 7010CT,...
Sony VGC-LS35E BLANK SCREEN
Do you mean after windows has booted you have a blank screen?
Boot into windows in safe mode (by pressing F8) during the boot up process.
When booted go into device manager and remove any video drivers under display adapters, if it asks to delete the files as well answer yes.
Reboot into normal mode and let windows find the driver for you.
Apr 19, 2009 | Sony Computers & Internet
Nintendo Wii Console Logo
61 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
