Question about HP Photosmart R707 Digital Camera
Sd card formatting
My r7c hp photosmart digital camara will not format the SD card.  It says the card has the wrong format.  When I hit the ok to format card it says try again later.
  • john cordey
    john cordey Jan 13, 2018
    This may be because a file is corrupted and unreadable...this happens for several reasons...trying to remove card whilst the camera is reading to it...opening card door during read write...failing battery whilst read write...if you have a corrupted card..try the HPUSB card utility which you can google and is free..this will correct the file system in a Ryder to format it...but you MUST find out what the correct file system is...usually Fat32 with cluster size of 1024 but in most cases ..once you have formatted with the hpusb you can then reformat on the camera....you should always format any card via camera before use as the cluster sizes can be confusing if formatted via pc.
  • 43 Answers
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Posted on Jan 29, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
It may actually be the card go on the cards manufacturer website and check
Posted on Jan 13, 2018
    Habit-Forming:
    New Friend:
  • 37 Answers
Hey, if you can't format SD card on digital camera, you can try to format it on your computer like Mac or PC. Here is the detailed guide: How to Format SD Card on Mac Windows Android and Camera
Posted on Jan 10, 2018
    New Friend:
Which kind of wrong formats your SD memory card has been detected as inside your digital camera? Is it in RAW format? How does it show on your PC? Is it still displayed as RAW file system there? If so, also do not panic! The wrong SD memory card file system format often can be fixed by simple formatting process. However, before you do any formatting process there, you are supposed to back up your card data well in case of losing important photos or other stuffs.
What you need now to recover data from this not formatted SD card is RAW file system SD memory card data recovery software.
Merely download and run a related data recovery tool to scan your card and take all possible photos and files back.
Best Wishes!
Posted on Nov 18, 2015
    New Friend:
My m425 hp photosmart digital camara will not format the SD card. It says the card has the wrong format. When I hit the ok to format it wont format the 4GB or the 8GB card why is this not working plz help
Posted on Aug 17, 2013
When i turn my camera on it says i need to format the SD card so i hit okay then it deletes all my pictures and says unable to format
The contacts on the card are dirty. Insert and remove the card several times and try it again. You can recover pictures off an erased card. Google SD card file recovery software.
Apr 17, 2016 | HP Photosmart 735 Digital Camera
When i put my sd card into my camera it needs to be formatted
Having received no response in over a month, I assume this is no longer a problem.
Jun 04, 2010 | HP Photosmart E327 Digital Camera
Will not recognise sd card
Is the SD slide protection switch unlocked? You will also need to format the memory card before it will work in your digital camara. Make sure the memory is compatible with your camara (too much memory and it won't work)
Nov 09, 2009 | HP PhotoSmart M627 Digital Camera
Can't format 2 GB sd card for HP 735 camera
Make sure the SD card is unlocked. There's a tiny switch on the side. Put it into the camera. Under storage, when you select the card, also select format.
Mar 13, 2009 | HP Photosmart 735 Digital Camera
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Sep 29, 2008 | HP Photosmart M525 Digital Camera
Wrong format on HP M425
Just fixed this problem on a M525 camera (same physical construction).
Do a search with M525 and format.
Feb 10, 2008 | HP Photosmart M425 Digital Camera
HP Photosmart R707 Digital Camera Logo
1,322 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
