Question about Nintendo Wii Fit for Wii
Wont allow me to set up body test. says step off board
I am trying to set up my wii fit, and it comes to the body test it says "please step off board" no ones on it. is this fixable?
    Problem Solver:
  • 14 Answers
Yes. Fo the Wii Fit Board Test.
Posted on May 28, 2009
Hi, I have just bought a Wii fit and game, on trying to set it up and do the body test, it keeps telling me to step off the board when I'm not on it and it won't let me continue. What can I do?
It looks like there is something wrong with the board. Try one of the following:
1. Power off the board and power back on.
2. Step on and Off from the board.
If this doesn't do anything, try this:
1. Power off Board
2. Power off the Wii and remove the main plug.
3. Put all on back after a minute or so and see if it does the same thing.
If it does the same thing, then I suggest you consult or return the Board to where you buy it from.
Hope this helps.
May 06, 2011 | Nintendo Wii Fit for Wii
I have finished setting upthe Wii fit and just about to start the body test but it keeps on telling me to step off the board and press A, even though I have not stood on the board. I have tried resetting...
It seems your Wii sensors are stuck, This is a hardware problem which requires you to open up the scale and should really be done so by a representative of Nintendo. Unless you know what you are doing, call up Nintendo or return it to the store and get another one.
Jan 01, 2011 | Video Game Consoles & Games
"communications with the Wii balance board have
Ok, that only happens when there is something blocking the signal to your Wii's antenna. Try moving the balance board further away from the television.
Dec 17, 2010 | Nintendo Wii Fit for Wii
My wii fit keeps say pleasae step off me and press a when i go to do the body test
Replace your Wii Fit Plus board and/or DVD disk. I had the same problem. The seller has gave me a new Wii Fit Plus set (instead of the 1st one), and everything was OK. I don't know if the problem was in the board or in the DVD disk.
Aug 14, 2010 | Video Game Consoles & Games
I keep getting the message to "step off and press A" for the body test.
You need to step off the pad, wait until it tells you to step on. Then you push A to conduct the body test. If your pad is turned off push the button on the front of the wii fit pad then repeat the first steps i described.
Aug 03, 2009 | Nintendo Wii Fit for Wii
Wii Balance Board thinks I'm on it all the time!
Make sure of a couple of things and try again -
If you are on semi-shag carpet, try using the little foot extenders. They may not seem like much but they can help.
If you are on moderate to thick carpet, you may need a board to set the Wii Fit Balance Board on.
If you are on a wood floor, you can (but don't have to) remove the little foot extenders.
Another little gremlin can be in those silicone covers. If you have one, I'll bet that's the culprit. As nice as they are to keep the board clean, they can actually attach to the non-moving part of the scale (the bottom) to the moving (surface) part. Be sure that your silicone cover is not interfering with the normal movement of the board.
Finally, be sure that you are always using YOUR setting while exercising or it will not be calibrated correctly. Also be sure that when you start, you are not on the board when it calibrates for the first time after turning it on. If the weight on the board differs by about 5 lbs or more than what it thinks you weigh, it will pitch a little wii fit.
I hope you find this advise helpful. If not, though, please don't label this advise as "inappropriate". A "Thanks for Trying" would be just fine.
Thanks for using Fixya.
Mar 23, 2009 | Nintendo Wii Fit for Wii
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test. Tried to do fit test...
If your Wii Fit Balance Board is on carpet, be sure to use the extra foot pads that came with your board. If your carpet is really thick, you may need to use a flat woodend board to set the balance board on.
Finally, make sure that you are NOT using your child's Miii to do your own balance test. Each user of Wii Fit must use their own Mii character.
If you don't like my suggestion, please don't rate this suggestion a '1'. If my suggestion doesn't help, the problem may exceed the scope of what can be answered here. You will need to contact Nintendo directly through their website and open a problem ticket.
Good Luck!
Jan 17, 2009 | Nintendo Wii Fit for Wii
Wii Fit Board won't register with Wii Fit software
Nintendo had me set and reset the console and then the Wii fit board. They also had me take out the batteries from the Wii fit board, and repeat the reset. Apparently this works in many cases. IT didn't work for me, so now I'm bringing the unit in for repair. I am just a week past my 90 day warranty- they are charging me 47 bucks to fix it! What a sham! that's half the cost of what I paid for the darn thing!
Jan 04, 2009 | Nintendo Wii Fit for Wii
Please be a bit more detailed in the problem. The Wii Fit Balance Board is very sensitive to weight shifts. Ensure that you allow the board to calibrate properly. To do this, I would suggest the following steps:
1) Place balance board on a sturdy, flat, smooth surface. If you have average-shag carpet, be sure to use the little adapters that fit over the feet. If the carpet is too thick, then it will NOT work properly. You may want to consider a small piece of plywood or something similar to set between the carpet and Balance Board.
2) Don't step onto the board until it has calibrated (this is when the board establishes its zero point). It will clearly say "Starting Up" followed by "Ok, Step On." After this, you can generally stay on the board unless a particular routine asks you to get off or for some reason it needs to recalibrate.
3) Finally, you must ALWAYS back out all the way to the Wii Fit Plaza (where you pick your Mii) if you change players. Once the board is configured for one player, it will only be suitable for that individual. Its sensitivity is based on an individuals weight. For instance, if the board is calibrated for a 3-year old's Mii, and an adult decides to play any of the routines on that Mii, the board will be over sensitive (calibrated for the lighter weight). Conversely, if an sdult's Mii is selected and a child plays a routine, the board may not detect the movement.
I hope these steps will help. If not, please offer a step by step explanation on what you are doing and I will try to reassess your situation.
Thanks!
Dec 29, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit for Wii Logo
363 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
