Question about Refrigerators
Fridge isn't cold
We have a GE Gss22wgph ww side-by-side refridgerator/freezer. About 1 year ago I replaced the motherboard due to loud whining behind the freezer. Now the refridgerator is not cold. The freezer seems to be fine, but nothing is staying cold in ther refridgerator. By the way, our water dispenser hasn't worked for a couple of years. I suspect the line may be frozen somewhere. The ice maker continues to work fine, but no water. The unit is less than 5 years old.
  • 544 Answers
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on May 28, 2009
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
I have a ge side by side dss25kgrd ww fridge. The freezer is freezing up an the fridge side is freezing the second draw. I had a service guy come an test the heater at the bottom in freezer.And said it ...
replace or first test the thermistors in both the freezer walls and refrigerator sidewall behind little plastic grilles ,they are easily tested by temp/voltage and are only $10.00 a piece,where as the motherboard is over$100.00
Mar 03, 2011 | Refrigerators
Refridgerator side of my side by side is Hot
Glad I was able to be of assistance. Did not post as a solution previously as I needed to ask a few questions first.
Jul 29, 2009 | Danby (DAR604BLS) Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Whineing noise\and leak on freezer side in the bottom of it
yes the water in the bottom is because your drain tubing is cloge thid is the small hole in the frezer area defrost your fridge use a wire to clear out the debri that clogs your tubing the water should drain in the pan where the compressor is thanks from gilles
Feb 10, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Refrigerator model GSS22WGPH whines loudly!
Sounds like the evap fan motor has a bearing going bad. Best to replace. Easy to for anyone who can use a screw or nut driver to do.
Jan 26, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
Refrigerators Logo
503 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
