Question about Tatung - TLM-1503 Monitor
WHITE SCREEN ONLY
HAVE ONLY WHITE SCREEN ON TATUNG TLM1503 MONITOR Westinghouse 17" lcd monitor comes on ok but in 5 minutes goes comepletely white
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have a Tatung LCD flat screen monitor TV. The te...
Failed backlight inverter circuits or the power supply for the backlight circuits has failed, you need to open it up and inspect the power suply first, look for bad caps with leaking/bulging tops. Post back what you find so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 24, 2010
Tatung tv v27mmcx
If you can't google it is had to be paid for. Or sometimes you have it in your manual.
Aug 04, 2014 | Tatung new co. lcd tv - v17aftw 17...
Every 5 to 10 minutes my monitor gets a white screen. If I turn off and back on the monitor, it goes away
You may loose connection between the logic board and the LCD panel connector, or the 5vdc feeding the panel is going out. Look to see if you notice anu caps with leaking.bulging tops.
Jul 13, 2010 | Acer AL1715 17" LCD Monitor
Screen goes white
Check the ribbon cable between the LCD panel T-CON board and the logic board. When you lose 5vdc feeding the LCD T-CON board the screen will glow white.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
May 31, 2010 | Dell E176FP 17" LCD Monitor
I have a Tatung lcd flat screen monitor tv. The television comes on there is sound but the screen is black. The tv is 5 years old. What would cause this?
May 20, 2010 | Tatung L17AMTN 17" Flat Panel LCD Monitor
When i turn on my westinghouse 17" LCD monitor it will have a sharp white bar appear through the screen in various sections then blotch out to completely white, after i let it warm up for about 20 minutes...
Hi
Well that's the age old question. Is it worth repair? The problem is probably 6 capacitors in the power supply that have aged significantly. In my shop those caps would run approx $2.00 each with a total labor charge of $50.00. Now whats the charge where you live? Then you can decide if it's worth a $62.00 repair or a new monitor for $150.00. Good luck
Mar 13, 2010 | Westinghouse Electric LCM-17v2 17"...
Tatung l17amtn lcd monitor
check the desktop and display settings from the control panel,, then from there go to screensaver and power,, make all to never and make your screensaver also to none.. and see
Sep 29, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
When I go to my desktop after a minute or two the entire screen goes white, how do I fix it?
This sounds like a power save issue or a screen saver problem and they are both on the same panel I will lead you to
Right click on an EMPTY part of the desktop then click properties
Click the screensaver tab then the POWER settings.
Make sure all the boxes say NEVER then APPLY.
Its up to you if you want it to ask for a password when it comes off the screensaver (my pref is for no) then click apply then ok.
When you are back at the screensaver tab change both the screensaver to one of the other windows defaults and also check how long before it goes to screensaver and maybe up that to at least 15 minutes unless you have a plasma screen in which case no more than 5 minutes.
you may need to click apply again then OK
now sit back and wait. and whilst you do that check the manual and controls for the monitor in case it too has a built in saver and if so make any changes you need there.
If you found this information useful then please click
Aug 13, 2009 | Relisys RLT1720 17" LCD Monitor
Acer 1716 17 inch LCD monitor, screen fuzzy w/white lines at rt
Common problem.
There are 8 small VRAM BGA chips.
1 or 2 of them needs REFLOW.
Basically board service.
Dec 16, 2008 | Acer AL1716 17" LCD Monitor
E-yama 17" flat screen monitor
It sounds like the internal bulb in your monitor is going out. Some LCD monitors go through a slight warm-up period but it should not be 5-10 minutes. You may want to change your Power Saving settings to prevent from going into standby. Here's how:
Right-click in an open space on your desktop
Choose Properties
Click the Screen Saver tab
Down at the bottom look for the Power settings
Change the Monitor Standby to NEVER
Click OK
Good luck!!
Oct 01, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
White monitor
You can degouse it.I think you placed your monitor in any magnetic field or near fan ac or any electric equepment.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | Xerox XA7-172i 17" LCD Monitor
Tatung - TLM-1503 Monitor Logo
91 people viewed this question
Top Tatung Computers & Internet Experts
Tony
kj henriksen
kj henriksen
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
