Question about Generic Memory Compaq Presario SR1215CL by HP AMD Sempron 3000+ 512MB 120GB CDRW/DVD w/XP [Refurb] [MIN90] PJ506AA... (PJ506AAR) PC Desktop
No signal to monitor. all cords are tight, and plugged in. no beeps when computer starts up. Can't test anything nothing shows on screen. Tried it on another computer, worked fine. amber light below g
No signal to monitor, lights all go on on computer, light on hard drive come on and back off, doesn't seem to be reading anything. All connections are checked, and plugged in.
  • ALBERT GARCIA
    ALBERT GARCIA May 11, 2010
    is there a indicator light on the monitor ?? is it blinking ? let me know , AJ
    Problem Solver:
  • 14 Answers
My brother had that problem. My dad just had to push some buttons. I know there somewhere.
Posted on May 28, 2009
2 Suggested Answers
SOURCE: no signal to monitor. all cords are tight, and plugged in. no beeps when computer starts up. Can't test anything nothing shows on screen. Tried it on another computer, worked fine. amber light below g
Check the connection which links the CPU and the monitor. Also check the power cable of th3e monitor
Thanks
Nilesh
Posted on Jun 03, 2009
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
My HP Pavilion dv9740us Notebook PC dosent start the screen is black
Doesn't start as in nothing happens when you hit the power button? Or are you saying the Desktop is black, but it seems like windows started and went through the boot process?
If nothing happens when you hit the power button:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 20, 2012 | Computers & Internet
My Sony VGC-RB34G is suddenly showing nothing on monitor except a sign "Check Signal Cable". I have cleaned and put back RAM tight. The fan works, I hear beeps when computer starts but no pic. I...
The computer should beep ONCE when starting-up.
More than one BEEP implies either that the video-card is not responding, or that it is not fully "seated" in its slot, or that the video-cable is not tightly connected.
Try a different video-card in your desktop.
Aug 26, 2011 | Sony VAIO VGC-RB34G PC Desktop
My HP L2335 Monitor wont display anything. I can literally turn it on (the led power light comes on and it turns green if plugged in and I can tell the backlight is on), but nothing will display no...
why not try a dead display on 2 machines 2 PCs
using only 1 data cable at a time why try to confuse it????????
the OSD must work, or the display is bad or the power supply to it is dead.
easy as apple pie.
the monitor has a tiny computer inside it (micro)
on mine, the data lines dead shows NO SIGNAL in the screen
every time you I power up my monitor with data cables pulled off.
best is to read the book for your monitor, and run all the tests it
tells you there,
Mar 13, 2017 | HP L2335 23 inch Monitor
I have a problem with my monitor it a mag 18" LT865b the power light comes on but nothing shows up on the screen i have tried many different things such as different power cords even when not pluged...
Most likely, one of two things are the problem. Assuming that your computer is actually starting up and it passes the POST (you'll get a single beep if you have a system speaker), then the monitor is likely bad. Check it by attaching another monitor to the computer to see if a signal is being put out by the computer. If you get a picture, you have definitely have a bad monitor. If there is no picture on the test monitor, then your video card may be bad.
If the computer is not starting correctly, I'd recommend disconnecting everything but the CPU and memory and possibly the keyboard and trying to boot it. If it's one of the peripherals like the CD/DVD that is bad, then you should get something on the screen (I have had this happen).
Oct 30, 2010 | Mag Innovision Computers & Internet
Acer AM5641-U5520A will not
If you removed the memory modules and there is no change then I would start disconnecting one device at a time to see if that is causing the problem. Start by disconnecting the cd/dvd rom and then try booting the computer. Then try disconnecting any floppy drives or pci cards(except for video card). If it has a pci/agp video card then you will need to remove it and test it in another computer or test a working one in the problem computer. If it has built-in video then you will need to test a working video card in the problem computer. It could also be an issue with the power supply so remove it and test it in another computer or swap it out with a known working power supply. Also check the mother board screws that hold the board to the chassi are tight(the board uses them as a ground). Blow any dust out of the case and verify that there are no loose connectors. Also verify that the monitor is not the problem by testing it with another computer. Usually when a CPU is defective the computer will not respond to anything and will act "dead" so it does not sound like the CPU. If everything else checks out then it could be a bad motherboard.
Dec 28, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Sep 07, 2009 | HP f2105 21" LCD Monitor
Get NO SIGNAL on Acer M1640~Monitor is Fine~Is CPU
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
Good luck
Jun 28, 2009 | Acer Aspire M1640 Refurbished Intel...
Monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
Apr 28, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Computers & Internet Logo
101 people viewed this question
Top Generic Memory Computers & Internet Experts
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
