Question about Cyclone Exercise & Fitness
I hav a cyclone sx6.0 maxfit treadmill,and a fault 1 comes up,pl hep
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: I have a Cyclane SX6.0
Check the reed sensor also known as the speed sensor. It is located on the front roller pulley. It is mounted to the frame and looks like a small black tube with a wire attached to it. What you need to do is to check if it is good by using an ohm meter.
1. Unplug the reed sensor
2. Place the red and black leads on the two wires
3. turn the flywheel so that the magnet (should be mounted on the pulley)passes by the sensor(make sure the sensor is only 1/8" away)
4. the meter should show the sensor opening and closing if it does not recheck the gap from the magnet and if it is good, replace the reed switch.
5. The other possibility is the magnet fell off the pulley and in this case you will need to superglue it back in place.
Let me know,i needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 10, 2011
My belt is slipping to one side and i no longer hav the manuel
hi
chek if it is level
and then turn rear roller bolt of treadmill to clockwise you should turn the side which is closer to the to the foot railing(i mean slipping to the side)
1 step
check if treadmill is level
2 put tread work on speed of 2-3 mph
3 turn rear roller bolt of slipping side 1/4 clockwise with small steps and you should see it going to center
Nov 25, 2010 | Cadence Weslo 927 Treadmill Walking Belt
Front rollerhas is rubber coated and the rubber has started to break up ,model is cyclone sx 9.0 max pro
This is a common problem with front roller that utilizes a coating that you described. Treadmill Doctor.com has these sleeves for icon fitness units they may work for your unit give them a shout they are in the state of Tennessee USA.
Aug 13, 2010 | Cyclone Folding Treadmill
Error code comes up after 5 seconds
hai,
please check the speed sensor
Jun 09, 2009 | Cyclone Folding Treadmill
Belt is slipping, even on the lowest power.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
As far as the manual, I have not been able to found it anywhere yet.
Jan 22, 2009 | NRS Stex 8025TL Attachable 17 Inch Lcd Tv...
Exercise & Fitness Logo
252 people viewed this question
Top Cyclone Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Cyclone Exercise and Fitnes Expert? Answer questions, earn points and help others
