Question about Brother LS-2125 Mechanical Sewing Machine
Bobbin case on brother sewing machine
Are there any video directions for installing bobbin on brother LS 2125?
  • robynulz May 29, 2009
    Thanks for your help.  The casing is out and I have to figure out how to get the bobbin holder back in now!
  • 128 Answers
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
HOW DO I PUT THE PARTS FOR A BOBBIN CASE BACK TOGETHER FOR A BROTHER LS 2125 SEWING MACHINE
IMHO, it may be more productive to buy a replacement bobbin case for your machine. The mechanics of the bobbin case are very important to successful use of the machine, so a lot of time and energy could result it no success. A non-OEM bobbin case could cost less than $10.
Amazon com Bobbin Case JO1313Z Brother Baby Lock Singer Janome Viking
Jul 15, 2016 | Brother Sewing Machines
Thread keeps breaking and underneath not sewing right
There may be a broken thread in the bobbin case effecting the lower thread tension. clean all parts and determine if the upper thread or lower thread is breaking if cleaning does not help. double check your machine threading and bobbin installation direction.
http://www.mastersewusa.com : this site has many operator manuals if the above suggestion does not help.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a LS-2125 brother machine, and when I sew the thread from the bottom catches and breaks. I have taken the bobbin casing apart and cleaned and oiled it, changed bobbins, tried to adjust the...
make sure that it is threaded right, and that you do not have your needle inserted backwards, flat side should face rear of machine, read your manual carefully. If you do not have one, go to www.brother-usa.com and you download one for free.
Sep 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have install the bobbin like the directions say , Everything is assembled right yet the sewing machine needle will not pick up the thread from the bobbin. It has always worked in the past. Please advise
Make sure that you have pulled the thread through the tension spring on the bobbin case and the tension spring in the bobbin case area on the the machine and hold the thread out so that when the needle comes down, as you move the wheel slowly towards you, it will hook it.
Jul 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE STITCHING UNDERNEATH IS OK BUT THE UPPER THREAD IS LOOSE AND ALSO SKIPS
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
Jul 11, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125i
hmm maybe you turning the side gear in the different direction. try turning it in counter clockwise direction
Sep 07, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother ls-2125 how to thread bobbin
all manuals for a brother sewing machine are downloadable at www.brother-usa.com
Apr 02, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
703 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
