Question about Sony KDS55A2000 55" HDTV
XL 5200 bulb replace and tv still down
I replaced the xl 5200. At power on the led blinks green three times, then blinks red three times. The red cycle continues. No TV.
  • ebtdm May 28, 2009
    I have done that, checking the fan and area for dust and noticed the door saftey switch. I am pretty sure that the door is closed properly. No improvements.
    With this advice in mind I used a spudging tool to depress the switch and all works fine. Then I realized that I misplaced the inner door that actually depresses the switch. Your advice was helpful and has now lead to the return of a functional TV. Thank you this problem is solved.
  • Sony Master
  • 8,617 Answers
3 blinks means the lamp cover door is nit properly attached. Remove the lamp door and reinstall it
Posted on May 28, 2009
  • Sonny Berry
    Sonny Berry May 28, 2009
    can you hear a click when you push in the door switch?
  • Sonny Berry
    Glad that I could assist you and glad to hear its working properly again.
My Sony KDS-60A3000 randomly turns off, then the red "Power LED" blinks three times repeatedly (not "Lamp LED"). We turn it back on, the process repeats again between 20-60 minutes.
3 blinks of Standby/power LED of Sony sets denotes a SMPS board [G-board] failure. . Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 16, 2016 | Sony KDS-60A3000 60" HDTV
KDS50A2020 When I turn it on it you can hear the
Hello, those sets were bad about the lamp, yes the lamp failing and they didn't break the part number on the lamp is a XL-5200. When I would have calls with this issue, I would say about 75% of the time the lamp fixed it....tks
Nov 04, 2013 | Sony KDS-50A2020 Television
My lamp is blinking red. I read that I should replace it with an XL-5200 lamp.
PN# for Lamp to Sony KDS50A3000 XL-5200
Mats has them for $129.95 1-800-628-1118
Look on EBay I have found Lamps for $85.00
Jul 24, 2011 | Sony KDS-50A3000 TV
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
May 30, 2009 | Sony KDS55A2000 55" HDTV
Wrong model showed up on my question - need new reply about part
ORDERED SONY PROJECTION REPLACEMENT LAMP - SHOULD ARRIVE IN ONE MORE DAY - KEEPING FINGERS XXX'D THAT THIS WILL RESOLVE THE PROBLEM - BUT THE TECH WAS EXCELLENT RESOURCE! I'M CONFIDENT IT WILL FIX THE PROBLEM AND THRILLED WE CAN DO IT OURSELVES AND SAVE $200! THANKS !
May 18, 2009 | Sony KV-36FV26 TV
TV powers off for no reason
Its your bulb on its way out.
the replacement bulb is a Sony XL-2400 But yours should definately be under warranty
Mar 20, 2009 | Sony KDF46E2000 46" Projection HDTV
Sony KDS55A2000 55" HDTV Logo
535 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
