Question about Bose Lifestyle 28 System
Remote not working with bose lifestyle 28 system.
My remote for my lifestyle 28 not responding at all to the remote even with fresh batteries.
5 Suggested Answers
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
SOURCE: Remote Code
codes for bose123
Posted on Feb 03, 2008
  • 8 Answers
SOURCE: how do i get my Bose Lifestyle remote to control
call bose tech support and register your lifestyle system with them, they in turn will start sending you update CD's those CD's may include the new IR databases that would help you find the right code. the other alternative is to call VIaSat and find out what brand's IR codes they are using( and in the IR menu on the bose try that brand's codes) A lot of manufacturers will use the codes from Motorola(worth a shot) the alternative option is to program a universal remote to control your bose, and all your equipment (if your equipment is hidden in a closet, get an RF remote, I program these for my clients all the time (for their bose systems))
Posted on Sep 12, 2009
SOURCE: Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Posted on Apr 08, 2010
Testimonial: "Thanks for your support. Unfortunately i had to send the system to Bose for repairs. Thanks anyways. "
How to reprogram the remote control rc 18t1-40
If replacement batteries were installed correctly and the remote still doesn't work, you may have to replace it.
May 24, 2015 | Bose Lifestyle 28 System
I have a bose lifestyle 28 system purchased back in 2003. The remote broke when it was dropped on the floor (no longer functions). Is it possible to repair the remote or buy a replacement for this older...
Exactly how "broke" is the remote? (pictures help here, but if you don't know how to post one, or how to keep it under 150KB in size, then be as descriptive as possible in a REPLY to this post.
Feb 27, 2011 | Bose Lifestyle 28 System
I have the bose av28 media center, life style 28, remote broke, i have a time warner clikr 5 universal remote can this control the bose 28 ?
No, only the Bose remotes will work with it! Bose doesn't let any other remote to work on their systems.
Dec 26, 2010 | Bose Lifestyle 28 System
Bose lifestyle 38 remote wont work i'm trying to reset the house code but "all off" followed by "enter" or follwed by"stored " is not working
I have a Bose Lifestyle 38 and the remote control stopped working effectively. I've tried several sets of fresh batteries, made sure that the electrical cord is not coiled up, and have checked the copper coil antenna within the remote to make sure it is connected. The remote does not make any noise or rattle when shaken. It will only work when held within a foot or two of the receiver, and even then often takes several button pushes to get a response. I've verified that the house code on the remote and the receiver are the same. Any ideas?
Oct 25, 2010 | Bose Lifestyle 38 DVD Home Entertainment...
I have a lifestyle 28 and for some time now the range within the remote can be used has reduced a lot, as a matter of fact, sometimes even as short as 4 meters away. I also have noticed that for some...
try t use a remote extender with multiple sensor wich can be use to extend the range of your remote or try chage the battery of your remote....
Sep 30, 2010 | Bose Lifestyle 28 System
My remote control does not work at a distance. if go 4 to 6 inches from the system it takes the command. what is wrong with my system/control system?
try putting fresh batteries into your remote control. if the batteries are low on power then the remote will not transmit very far
Sep 26, 2010 | Bose Lifestyle 28 System
My Bose Lifestyle 28 III system is about 2 1/2 years old. The remote has just stopped working---nothing at all. I have tried 4 sets of new batteries and still no luck. Any suggestions besides purchasing a...
A new remote is the simplest and best bet. I know of no way to repair a remote without making it irreparable. Though you might check the infrared LED i the front. Does the light on the remote illuminate when you press a button?(assuming it has that.)
Jun 22, 2010 | Bose Lifestyle 28 System
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
call tech support to see if they can help, they might set up a repair for you
Nov 19, 2006 | Bose Lifestyle 28 II System
Bose Lifestyle 28 System Logo
558 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
