SOURCE: I am getting verticle black streaks when I print, please help.
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
SOURCE: Just replaced the glass on an HP C4150. When I use
Look for debris on the scan head face--all it takes is one tiny speck to create one line down the paper. Make sure the connector for the head is plugged in securely on both ends.
SOURCE: Verticle lines printing on laser printer
Check the fuser. If it is the fuser, you should be seeing 3 dark lines on the fuser film. Here is the picture about how the film looks like:
Changing the film usually solve the problem. However changing the film itself is difficult. You have to remove and basically disasseble the fuser, and change the film. However it is fairly cheap and if you decide you would like to save some money, here is the link available in ebay:
http://cgi.ebay.com/Fuser-Film-Sleeve-HP-LaserJet-P3005-RM1-3740-/250558576965?cmd=ViewItem&pt=BI_Toner&hash=item3a56747945
Or, simply search for 'P3005 Fuser Film' and you will find a lot.
Other than that, you can change the entire fuser. Please note that fuser for P3005 is not consumer installable part. You still have to take out some parts in order to change the fuser.
The parts are available from many parts supplier. Simply google 'P3005 fuser'. Usually around $100 for a refurbished fuser.
You can also recycle your old fuser and get some moeny! (about $15-$25 per fuser).
