Question about iRobot 5800 Scooba Vacuum
It keeps telling me check tank
It sounds like it is pumping the fluid but then the check tank comes on. We have taken it apart, cleaned, refilled and we still get the check tank. It primed about 5 or 6 times before the warning. I have the 5800 and have not used it very often. The last time I had no problems. The manual is useless since it tells you to go to 18 and then 24 and then back to 18. Can you help?
    Sniper:
  • 61 Answers
Prime Scooba's pump, as described here, but use water instead of air to prime the pump. Water is more effective. You'll have a little puddle under the robot if you've been successful.
Then rinse the tank through all four ports on the underside-- one round, two oval, one large and curved. All four are in a row at the bottom of the transparent area. You'll probably dislodge some clots of debris and sediment. Then refill the tank and run the robot. That ought to do it. If it doesn't, call customer support at 1-877-855-8593.
Posted on May 29, 2009
  • smlamb23 Nov 07, 2010
    This solved the problem of chronic "check tank" as well as not laying down fluid!
How do you remove the lower handle?
Check the clean water holding tank. I had this problem and found that was a crack near the outlet on the bottom of the tank. I replaced the tank and resolved the problem. I have taken this machine apart several times, if the tank is not the problem with yours, check the water tube.
Apr 26, 2015 | Hoover F7425-900 SteamVac V2 Widepath...
Biseell little green machine wont squirt water out
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Bissell 9300 will not spray liquid
I've got the 9300. Same problem occured during warranty period. They replaced the pump and it has worked fine since. The service person said never to put hot water in the tank (whish is what I was doing). If you put hot water in the tank, with the heater on, the water gets boiling hot and then the plastic impeller on the pump expands and the pump shaft simply spins and does not turn the impeller. Don't know if it is true or not, but his explanation sounded reasonable. Since then, I have used only lukewarm water in the tank and it still squirts fine (about 2 years). I also shut the heater off and squirt some fresh water in order to keep the pump cooler if I need to pause the cleaning for more than a few minutes. I took it apart one time to see what is inside. The pump is not real easy to get to. Good luck.
Mar 28, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The water doesn't come out. I've taken it apart
The reason the water is not dispersing is because the pump belt is probably stretched or worn. You can get belts and view the manual here:
Bissell 1699 ProHeat Belt and Manual
Dec 03, 2009 | Bissell 1699 ProHeat Clear View Upright...
My Scooba floor cleaner "check tank" light stays on even after it's refilled and everything cleaned but still will not work. It just keeps beeping at me when I try to start it. How do I reset it or get...
Flush out the solution valve with water (aka "prime the pump"). Use water, not just air, because water will clear any obstructions that may be in the lines. Also, rinse your tank through the four ports on the *underside*-- one round, two oval, one large and curved, all four in a row. Rinse them really thoroughly with warm water, then refill the tank and try the Scooba again. If it doesn't work, call us: 1-877-855-8593.
Aug 16, 2009 | iRobot 5800 Scooba Vacuum
Soap or water will not come out
Several things can cause this.
First thing, I check to see if water is coming out the attachment hose. If it is coming out the hose and not the bottom, most likely you have a clogged heater. The heater is located inside the lower handle and just needs to be taken apart and cleaned out. Fairly simple repair, and it is common.
If it sprays for just a few seconds when you first turn it on and then stops, that's a classic sign of a bad pump, and it will need to be replaced.
If it isn't pumping at all out of both the bottom or the hose, there a few simple things to check. Make sure there is fluid in both tanks. It will not work with one of the tanks empty. Make sure the flat belt isn't broken( there is an access panel on the side of the unit to ger to the belt). The flat belt runs the pump. Both of the tanks have a round rubber gasket that wraps around the valve and they tend to come off and get stuck in the inlet valve of the machine. It just needs to be put back on the tank.
There are numerous reasons why this machine might not pump, but these are a few of the most common ones.
Good Luck
Nov 24, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell spot bot
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
I have a feeling is this the solution for most people whose manual mode works fine but, automatic mode stops with lights a' flashing. Why manual still works though is a mystery to me. You'd think all modes wouldn't work then.
Nov 25, 2007 | Vacuums
Stuck on check tank indicator
If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
2. Remove and reseat the brush head
3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
With the tank removed, press the Power button and then the Clean button.
If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
Below is a link to a diagram of these steps for visual reference:
Title: Scooba is not putting down cleaning solution
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
Nov 01, 2007 | iRobot 5800 Scooba Vacuum
Will not spray
I have the same problem. I took it apart and found that the water pump had leaked and burned out the water pump motor. It's a $20 part.
Aug 16, 2007 | Bissell 1425 Little Green ProHeat Handheld...
iRobot 5800 Scooba Vacuum Logo
520 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
