Question about Mitsubishi WS-55859 55" Rear Projection Television
Dm board on ws55859
Can just change the whole board out? because I'm not good at solder
  • Bigums Oct 22, 2007
    I have ws 55859 with the same problem eveyone has (the Blinking Light) I'm not good with a ironing gun can I just change the whole board out ? and about how much will it cost
  • Anonymous Feb 22, 2008
    I have the blinking green light that will not reset.
  • 59 Answers
That board is expensive  $500.00 or more
Posted on Oct 22, 2007
SOURCE:
The green timer light is blinking with no interruption on my WS-55859. TV will not power on after the reset button is reset or is disconnected from power.
Thats almost always caused by failed DM capacitors on the DM power board. There are 7 that will need replacement. There is a repair kit called the WS55859 DM repair kit which has the caps and the CD with repair instructions available from www.tvrepairworld.com
Jul 07, 2011 | Mitsubishi Televison & Video
Timer light continous blinking,tv won't turn on!!!
Thats a common problem thats almost always caused by failed capacitors on the DM powerr board. You can get the WS55859 DM repair kit from www.tvrepairworld.com the kit contains the upgraded capacitors and the CD with repair instructions.
May 30, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Green light flashing in the front ?
SLinteriors posted this on another page and saved me big bucks.
Here's a bit more detail:
The flashing green timer light after a lightning storm seems to be a very common problem with old Mistubishi rear projection TV's. A friend and I had the exact same problem.
Using this and other sites, I spent $36 bucks and a little time with a soldering iron to replace the capacitors on the DM board and got mine up and running (WS55859). I've never really worked on electronic circuit boards before, but the helpful advice at these sites got me up and running. Definitely check it out before you hire someone or replace your TV:
Repair Kit with instructional CD available at:
http://www.tvrepairworld.com/mitsubishi_repair_kits
for under $40 plus shipping.
Discussion of process in detail at:
http://www.hometheaterspot.com/showtopic.php?tid/137881/
for the WS55859 model, which may be a little different.
Jul 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green light flashing what does that mean?
The steady blinking green timer led is usually caused by failed capacitors on the DM and Power board which prevent the set from completeing the Boot sequence
Jul 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green timer light flashing tv wont come on result of power surge
Your power source seems to be the problem, replace the part (located inside the television) and the problem will be solved.
Jul 18, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
I have a WS 55859 and after power outage i got the green POWER light blinking. I replaced all seven capacitors 1000uf but i still can't switch it in? Any other advice? Rgds FM
If replacing the 7 caps doesn't work I then try to re-solder the small 8 pin ICs. Be very careful and try to avoid cooking it or leaving a solder bridge. If that doesn't work either you'll have to replace the DM-POWER board. You'll beed a Mits authorized service center to order the part. Goodluck.
Jul 05, 2010 | Mitsubishi WS-55859 55" Rear Projection...
MITSUBISHI DIGITAL TV WS-55859 GREEN LIGHT FLASHING WON'T SHUT OFF EVEN AFTER RESET. IT HAPPENED AFTER POWER OUTAGE.
This could mean the DM (HD tuner) failed. In the future connect your TV to a good surge protector. The manufacturer's solution is to replace the module and swap the memory from the failed part to the new one. (Except for the memory it is just an unplug one and plug in the new one.)
If you are handy with a soldering iron, you may be able to fix this by opening the DM module and removing 8 capacitors (as I understand the board) and replacing them. All 8 are 1000uf 16v 105C Capacitors
This URL has an good explanation of the process: http://www.hometheaterspot.com/fusionbb/showtopic.php?tid/137881/
I hope this helps.
Jun 19, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Front panel light blinks with no audio and video
Might be a little late since this was asked back in May, but...
The flashing green timer light after a lightning storm seems to be a very common problem with old Mistubishi rear projection TV's. A friend and I had the exact same problem. And the following solution has appeared on numerous posts here and other websites. Thanks to Slinteriors who originally put the retail parts link:
May 23, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Ws55859
Misubishi WD-5237
T.V. will come on and display the satellite channel guide and will change channels,but will not display picture. Could this possibly be bad spot in coil?
Mar 17, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
